Help with pic16f690 -max232cpe
Results 1 to 37 of 37
    May 2008
    Italy
    That did nothing, is there a way to check if the signal is coming out from pin 9 on max232?
    Yes place a led with 1K in series from pin 9 to gnd.
    But, I am more interested on how many IO pins you are using. Now If you have inputs pins floating (not connected) this can produce wierd result.
    I noted in your code, that you are not setting the tris registers, please do it. Set all non used pins as output and place them to a logic zero.
    Example (I assume you are using only the serial pins) :
    TrisA = %00000000
    PortA = 0
    TrisB = %00100000 ' if the only input is pin 10 Rx
    PortB = 0
    TrisC = %00000000 ' if none of the portC pins are used
    PortC = 0
    The above code has to be written on top of your code. It will set all non used port as outputs @ logic zero, avoiding to leave inputs floating.
    If your arrangement is different modify the tris command to suite your need.
    Al.
    Apr 2010
    Quote Originally Posted by aratti View Post
    TrisA = %00000000
    PortA = 0
    PortB = 0
    PortC = 0
    Al.
    I did that now but still nothing usful, it seems that the data is coming out from the max but it wont register at all i do get something when i send like 200 times with 10ms
    Is the ground (pin #5) of the serial connector really connected to +5 volts like the schematic?
    Apr 2010
    No just i did not lay to much work in the schematics. but no it's connected to ground
    Apr 2010
    here is the updated right one.
    And i found a probleme wich seems od. when using any freq other than 4mhz the buad rating is all wrong.
    check out this forum discussion about it
    http://www.mikroe.com/forum/viewtopic.php?f=13&t=11114
    Apr 2010
    I found another forum thred about turning the MCLRE_OFF
    how do i do that?
    Quote Originally Posted by krise86 View Post
    how do i do that?
    Check the configuration word register. Page 201 of the data sheet.
