Help with pic16f690 -max232cpe
Results 1 to 37 of 37
    Apr 2010
    Quote Originally Posted by aratti View Post
    Yes! Max232 is a voltage level translator.
    Yes!
    Al.
    That did nothing, is there a way to check if the signal is coming out from pin 9 on max232?
    May 2008
    Italy
    Yes place a led with 1K in series from pin 9 to gnd.
    But, I am more interested on how many IO pins you are using. Now If you have inputs pins floating (not connected) this can produce wierd result.
    I noted in your code, that you are not setting the tris registers, please do it. Set all non used pins as output and place them to a logic zero.
    Example (I assume you are using only the serial pins) :
    TrisA = %00000000
    PortA = 0
    TrisB = %00100000 ' if the only input is pin 10 Rx
    PortB = 0
    TrisC = %00000000 ' if none of the portC pins are used
    PortC = 0
    The above code has to be written on top of your code. It will set all non used port as outputs @ logic zero, avoiding to leave inputs floating.
    If your arrangement is different modify the tris command to suite your need.
    Al.
    Apr 2010
    TrisA = %00000000
    PortA = 0
    PortB = 0
    PortC = 0
    Al.
    I did that now but still nothing usful, it seems that the data is coming out from the max but it wont register at all i do get something when i send like 200 times with 10ms
    Is the ground (pin #5) of the serial connector really connected to +5 volts like the schematic?
    Apr 2010
    No just i did not lay to much work in the schematics. but no it's connected to ground
    Apr 2010
    here is the updated right one.
    And i found a probleme wich seems od. when using any freq other than 4mhz the buad rating is all wrong.
    check out this forum discussion about it
    http://www.mikroe.com/forum/viewtopic.php?f=13&t=11114
    Apr 2010
    I found another forum thred about turning the MCLRE_OFF
    how do i do that?
