You can put them in your program, or you can edit them in PBP files. Either way, you will have to go to your PBP files, and find the one specific to your chip. Look for the 16f690.inc file, and either edit, or comment out the line
;        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
        __config _HS_OSC & _WDT_ON & _MCLRE_OFF & _CP_OFF
It is easiest to just to comment it out, then copy and paste it back into the same file with your changes. That way you will be able to go back to the default. Many people prefer to comment it out in this file, then put it into their PBP code. To to this, you would add a line at the top of your program, like this:
@        __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
See http://www.picbasic.co.uk/forum/showthread.php?t=543 for a more in depth look
