krise86, Depending on the capacitator values used with a MAX-232 the charge pump voltages should be around +-6 volts to +- 9 volts. The TRUE RS-232 spec calls out for mark,space voltages of +- 3 volts minimum... Some laptop computers now days do not meet the TRUE RS-232 spec limits as some only put 0 to +5 volts... That is why some laptop computers don't have a solid serial communications...
heh.... well u think stupid you, and yes stupid me. not going to that mistake again. So then i started to check the connection on my breadboard and pow it splits in the middel where i had put my pic. so basicly i had half of the earth connections not connected. And i connected it this way after it was connected the right way. but then i did not have the pin 5 from rs232.
