That's the code.Code:DEFINE OSC 4 ANSEL = %00000000 ' Pins to be Digital ANSELH = %00000000 ' Pins to be Digital TrisA = %00000000 PortA = 0 TrisB = %00100000 ' if the only input is pin 10 Rx PortB = 0 TrisC = %00000000 ' if none of the portC pins are used PortC = 1 CM1CON0 =0 CM2CON0 =0 CM2CON1 =0 adcon1=0 Include "modedefs.bas" DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 24h 'sets bergh = 1 or 20h sets = 0 'define HSER_BAUDCON 1h ' 0h DEFINE HSER_BAUD 2400 '16468 DEFINE HSER_SPBRG 103 DEFINE HSER_CLROERR 1 rxVal Var word start: Hserout ["Hello World", 13, 10] ' Send text followed by carriage return and linef main: Hserin 10000,start,[rxVal] ' Get a char from serial port Hserout ["Got value:", rxVal] ' Send char out serial port pause 30 goto main
