Help with pic16f690 -max232cpe
Results 1 to 37 of 37
    Apr 2010
    Quote Originally Posted by aratti View Post
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0,16%
    Tray to replace your USART setting with the one given above.
    Al.
    Thx for replying, but i have tried that to. and still no go. when i change the usart settings to use 2400 bauds it wont work at all, then i just get alphas and numbers.
    can there be something wrong with my connections. iv tried with 2 max232 and same result. have i connected something wrong would this result in such an error.
    and one thing more, when i send a alpha, let's say "t" if i repeat that like 10 timer with 50ms pause i revice the correct letter back maybe once <- if i look a hserin and hserout
    May 2008
    Italy
    What kind of terminal are you using?
    Can you post your wiring ?
    Al.
    Apr 2010
    Al.
    Well it looks like i found the probleme, i looked over the max232 data sheet and i frogot to connect vcc and gnd
    Now i recive the expected output but it wont read the input.
    'intcon=0 ' Interrupts disabled
    cm1con0=0 ' Comparator 1 disabled
    cm2con0=0 ' Comparator 2 disabled
    'cm2con1=0 ' Comparator 2 disabled
    ANSEL=0 ' Pins to be Digital
    ANSELH=0 ' Pins to be Digital
    Include "modedefs.bas"
    DEFINE HSER_RCSTA	90h
    DEFINE HSER_TXSTA	24h 'sets bergh = 1 or 20h sets = 0
    'define HSER_BAUDCON 0h ' 0h
    'DEFINE HSER_BAUD	9600 '16468
    DEFINE HSER_CLROERR 1
    rxVal Var Byte
    HSEROUT ["Waitin signal"]
        hserin [rxVal]
        hserout [rxVal]
        'HSEROUT ["Test should work"]
        pause 20
    Any ideas?
    And Thx for the help so far, sorry for not checking the schematics better
    and im using 232analyzer terminal software
    May 2008
    Italy
    Can you post the schematic?
    Al.
    Apr 2010
    Al.
    May 2008
    Italy
    Something doesn't work with your wiring:
    Max232 pin 10 should be connected to pic 16F690 pin 10 (RB7 Tx)
    Max232 pin 9 should be connected to pic 16F690 pin 12 (RB5 Rx)
    Connect a decoupling capacitor 10nF from Vdd to Vss on pic power pins.
    Al.
    Apr 2010
    Well it is connected that way pin 10 -> rb7 and pin9 -> rb5
    The 16f690 was not in the schematics program but that how i connected it.
    but im reading -10v on rs232 pin 3 and 5 is that right?
    I dont have a 0,01uf can i use 0,1uf?
    wait i think it's on the demo board
