16 bit PWM using CCP1
Results 1 to 40 of 61
    Default Re: 16 bit PWM using CCP1
    Hi, Talatsahim
    First have a look to how PBP shares its variables with asm ...
    Quote Originally Posted by Acetronics2 View Post
    Hi, Talatsahim
    _WhatsThat ?
    For starters, There is NO 16 bit compare register for PWM use. The upper byte is shared with a few other bits of config. There is ONLY 10 bit's available for PWM use in hardware. Read the data sheet for the processor you are using.
    EN82fn
    Nov 2009
    Thanx Dave,
    I use 10 bit hardware PWM. But I need more resulation. I such a little trick
    Talat
    What Acetronics2 is trying to say is, when accessing PBP variables inside of an ASM routine you need to prefix an underscore before the variable name such as "movf _PWM_VAL,W ; lb"
    As far as getting more resolution from the PIC processor, Your out of luck. You can always build your own digital pwm circuit with hardware if you are so inclined.
    EN82fn
    Nov 2009
    Hi Dave,
    This is just copy-paste error..
    What's interesting is that, these codes do not work to as 8-bit (10 bit too)
    Thanx
    So, Microchip themselves and previous posters in the this thread (Darrel, Bruce, Norm) are wrong then, what am I missing?
    When using the CCP module in PWM mode it's limited to 10bits resolution. But if you use it in compare mode, the way that the application note describes you can get 16bit resolution but:
    1) You won't be able to get 100% dutycycle
    2) The maximum output frequency will be limited to ~122Hz @32MHz.
    3) You'll get some CPU load from the interrupt processing.
    4) You need to deal with assembly code in the ISR (or deal with more "CPU load" if using DT-Ints)
    Jun 2009
    Sc*nthorpe, UK
    But Darrel did not do this in his code, prefix with "_". Also as Talat has said he is following Darel's example for "16 bit PWM using CCP1" which obviously worked for Darrel, Bruce and Norm.
    So Talat 16 bit PWM is possible. I have read the whole thread and the datasheets for the 18F452 and the chip you are using 16F1827.
    The first possible issue Darell said his code was for 18F's only in post 3 does anyone know why not 16F's? The 16F has CCPx compare mode.
    With regard to the 16F1827 I think CCP4 has the required features needed and CCP1 does not but I need more time to re-read the datasheet but in the meantime it would be helpful if some one could confirm which CCPx should be used.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by EarlyBird2 View Post
    Having dealt with the "_", wild goose chase, which had nothing to do with the problem any ideas?
    Nov 2009
    Hi, Acetronics2
    This is part of code. Variable sharing, what is wrong?
    Thanx
    Last Post: - 14th June 2016, 07:55
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
    Last Post: - 6th March 2005, 01:07
