post 35 is wrong pie1 is not in bank0 either
Code:Asm PWM_INT CHK?RP CCP1CON movlw 9 ; compare mode clrf CCP1CON ; clear reg movwf CCP1CON ; Set reg CHK?RP PWM_VAL movf PWM_VAL+1,W ; hb CHK?RP CCPRIL movwf CCPR1H ; put CHK?RP PWM_VAL movf PWM_VAL,W ; lb CHK?RP CCPRIL movwf CCPR1L ; put banksel 0 bsf INTCON,7 ;GIE = 1 bsf INTCON,6 ;PEIE = 1 Enable peripheral interrupts CHK?RP PIE1 bsf PIE1,0 ; TMR1IE= 1 Enable TMR1 BANKSEL 0 bcf PIR1,0 ; TMR1IF = 0 Clear Timer1 Int Flag RETFIE ; Return from Interrupt EndAsm
it just gets worse
