16 bit PWM using CCP1
Results 1 to 40 of 61
    Default 16 bit PWM using CCP1
    I am trying to do 16 bit PWM as per Tip#10 16 bit Resolution PWM page 40 (3-10) Microchip Tips 'n Tricks
    Basically when TM1 value equals the CCP1 (PWM duty) setting the CCP1 interrupt sets PORTC.2 low (works OK).
    When the free running TM1 interrupts it is supposed to set PORTC.2 high (doesn't).
    As a test CCP1 can be configured to toggle (this works OK as see in ISIS) but if configured
    to set low for PWM the pin cannot be set high again even though CCP1 int is cleared.
    The following code tries to set pin high in TM1 interrupt.
    Norm
        'FL PIC18F4520
        ; @ __CONFIG _CONFIG1H, _OSC_XT_1H
         @ __CONFIG _CONFIG1H, _OSC_HSPLL_1H
         @ __CONFIG _CONFIG2L, _BOREN_ON_2L
         @ __CONFIG _CONFIG2H, _WDT_ON_2H
         @ __CONFIG _CONFIG3H, _MCLRE_ON_3H & _PBADEN_OFF_3H
         @ __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
        DEFINE OSC 40
        Clear
        sSEROUT_PIN VAR PORTA.2
        sBAUD CON 16416  '16416 = 19200 BAUD
        wsave VAR BYTE bankA system    ' Saves W
        ssave VAR BYTE bankA system    ' Saves STATUS
        yTEMP VAR Byte
        wDUTY VAR Word
        wDUTY = 32768 '32768 = 50% DUTY PWM
        '16 BIT CCP1 PWM
        Input PORTC.2       ' Disable the HPWM output while things are being setup
        RCON.7 = 0          ' 0 DISABLES PRIORITY LEVELS ON INTERRUPTS (16F COMPATABILITY)
        T1CON = %10110000   ' Turn off Timer1 with a Prescaler value of 1:8
        PIE1 = %00000101    ' enable CCP1,  TMR1 overflow interrupt
        INTCON = %11000000  ' enable global and peripheral interrupts
        Output PORTC.2      ' Set PORTC.2 (CCP1) to output
    '    CCP1CON = %00000010   'TOGGLE PORTC.2 ON MATCH TM1 WITH DUTY ********** OK ************
        CCP1CON = %00001001   'LOW PORTC.2 ON MATCH TM1 WITH DUTY ?????????? NOT OK ???????????????
        T3CON = %00000000
    '    CCPR1L = wDUTY.LOWBYTE
        CCPR1H = wDUTY.HighByte
        CCPR1L = wDUTY.LowByte
        DEFINE  INTHAND myint
        Goto START    'Jump over the subroutines
      '**** ASSEMBLY INTURRUPT ROUTINE ****
      Asm
    myint    ;KEEP LEFT
      ; Save the state of critical registers
          movwf    wsave            ; Save W
          swapf    STATUS, W        ; Swap STATUS To W (swap avoids changing STATUS)
          clrf    STATUS            ; Clear STATUS
          movwf    ssave            ; Save swapped STATUS
      EndAsm
    '     yTEMP = yTEMP +1
    '     SerOut2 sSEROUT_PIN,sBAUD,["INT ",DEC yTEMP,13]
        PIR1.2 = 0 ' CLEAR THE CCP1 INT FLAG
        High PORTC.2          '???????????????? DOES NOT SET HIGH ?????????????????
      Asm
            bcf     PIR1, 0            ; Clear interrupt flag
          swapf    ssave, W        ; Retrieve the swapped STATUS value (swap To avoid changing STATUS)
          movwf    STATUS            ; Restore it To STATUS
          swapf    wsave, F        ; Swap the stored W value
          swapf    wsave, W        ; Restore it To W (swap To avoid changing STATUS)
          retfie                   ; Return from interrupt
      EndAsm
      '**** END ASSEMBLY INTURRUPT ROUTINE ****
        START:
        PAUSE 800
        SerOut2 sSEROUT_PIN,sBAUD,["START",13]
        T1CON.0 = 1   'TMR1 ON
        MAIN:
        yTEMP = yTEMP +1
        SerOut2 sSEROUT_PIN,sBAUD,["LOOP ",Dec yTEMP,13]
        PAUSE 500
        Goto MAIN
    Hi Norm,
    To set the pin High, simply clear the CCP1CON register, then load it<sub>(Bruce)</sub> with the compare mode again %00001001 (9).
    And, only do it on a Timer1 interrupt. The CCP changes the pin low on its own, so you don't need to enable the CCP interrupt.
    A few other things are either not needed or can be done differently.
    Have a go at this ...
        'FL PIC18F4520
        DEFINE OSC 40
        Clear
        yTEMP VAR Byte
        wDUTY  VAR WORD EXT    ' map wDuty to CCPR1L:H as a word
        @wDUTY = CCPR1L
    START:
        ADCON1 = $0F           ' disable analog functions
        CMCON = 7              ' disable comparators
        '16 BIT CCP1 PWM
        T1CON   = %00110000    ' Turn off Timer1 with a Prescaler value of 1:8
        PIE1    = %00000001    ' enable TMR1 overflow interrupt
        CCP1CON = %00001001    ' LOW PORTC.2 ON MATCH TM1 WITH DUTY
        OUTPUT PORTC.2         ' Set PORTC.2 (CCP1) to output, starts High
        wDUTY = 32768          ' 32768 = 50% DUTY PWM
        T1CON.0 = 1            ' TMR1 ON
        PAUSE 800
    MAIN:
        yTEMP = yTEMP +1
        PAUSE 500
    Goto MAIN
      '**** ASSEMBLY INTERRUPT ROUTINE ****
      Asm
    myint
        movlw     9                  ; %00001001 compare mode, low on match
        clrf      CCP1CON            ; clrf added per Bruce's suggestion
        movwf     CCP1CON            ; Set Pin to default state (High)
        bcf       PIR1,0             ; Clear Timer Int Flag
        retfie    FAST               ; Return from interrupt with shadow regs
      EndAsm
    P.S. Using both CCP's with this method would make a great 2 channel hardware driven servo driver.
    Dutycycles between 2500-5000 would give pulses between 1-2ms at ~40hz.
    Last edited by Darrel Taylor; - 14th December 2009 at 03:00. Reason: Servo's + Bruce's Fix
    Default 2-CH Hardware Servo Driver
    And since you made me think of it ...
    Here's a 2 channel Hardware Servo Driver, that uses Timer1 and both CCP modules in Compare mode.
    With an 18F.
    Servo outputs are the CCP? pins.
    Pulses will be continuous at ~40hz, regardless of MainLoop activity.
    Cheers ...
    '*  Name    : 2CH_Servo.pbp
    '*  Author  : Darrel Taylor
    '*  Date    : 12/13/2009
    '*  Notes   : 18F's only
    @ __CONFIG _CONFIG2L, _BOREN_OFF_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H
    CLEAR
    DEFINE OSC 40
    ;----[User Selections]------------------------------------------------------
    MoveSpeed CON 3                      ' movement speed smaller = faster
    PosRange  CON 900                    ' position is 0-900, 0.0-90.0 degrees
                                         '             450 is Center
    CCP1pin   VAR PORTC.2                ' Specify the pin that CCP1 uses
    CCP2pin   VAR PORTC.1                ' Specify the pin that CCP2 uses
    ;----[Variables and Aliases]------------------------------------------------
    Servo1    VAR WORD                   ' Position for Servo1
    Servo2    VAR WORD                   ' Position for Servo2
    DutyHold1 VAR WORD BANK0 SYSTEM      ' holds next dutycycle, synch with PWM
    DutyHold2 VAR WORD BANK0 SYSTEM      '
    TempW     VAR WORD                   ' temporary variable
    POS       VAR WORD                   ' loop counter variable
    TMR1IE    VAR PIE1.0                 ' Timer1 Interrupt Enable
    TMR1IF    VAR PIR1.0                 ' Timer1 Interrupt Flag
    TMR1ON    VAR T1CON.0                ' Timer1 ON bit
    GIE       VAR INTCON.7               ' Global Interrupt Enable
    PEIE      VAR INTCON.6               ' Peripheral Interrupt Enable
    ;----[Initialization]-------------------------------------------------------
    Init:
        T1CON   = %00100000              ' Timer1 off, Prescaler 1:4 (40mhz)
                                         '          1:2 (20mhz), 1:1 (10mhz)
        TMR1IE  = 1                      ' Enable TMR1 overflow interrupt
        TMR1IF  = 0                      ' Clear  TMR1 interrupt flag
        PEIE    = 1                      ' Enable peripheral interrupts
        GIE     = 1                      ' Enable global interrupts
        CCP1CON = 9                      ' Low on match TMR1 with DUTY1
        CCP2CON = 9                      ' Low on match TMR1 with DUTY2
        OUTPUT CCP1pin                   ' Set CCP1 pin to output, starts High
        OUTPUT CCP2pin                   ' Set CCP1 pin to output, starts High
        Servo1 = PosRange/2              ' Start at Center Position
        Servo2 = PosRange/2
        GOSUB SetServos
        TMR1ON = 1                       ' turn ON TMR1
        PAUSE 2000                       ' allow time for servo to Home
    ;----[Main Program Loop]----------------------------------------------------
        FOR POS = 0 TO PosRange          ' move both from one end to the other
            Servo1 = POS
            GOSUB SetServo1              ' Set servo1's position
            Servo2 = POS
            GOSUB SetServo2              ' Set servo2's position
            PAUSE MoveSpeed              ' movement speed
        NEXT POS
        FOR POS = PosRange TO 0 STEP -1  ' move servo1 back to home
            Servo1 = POS
            GOSUB SetServo1
            PAUSE MoveSpeed
        NEXT POS
        FOR POS = PosRange TO 0 STEP -1  ' move servo2 back to home
            Servo2 = POS
            GOSUB SetServo2
            PAUSE MoveSpeed
        NEXT POS
        PAUSE 1000
    Goto Main                            ' rinse and repeat
    ;----[Convert Position in degrees to dutycycle]-----------------------------
    SetServos:                           ' Set both Servo's dutycycles
        GOSUB SetServo1
    SetServo2:                           ' scale Posistion to 2500 Dutycycle
        TempW = Servo2 * 2500
        TempW = DIV32 PosRange + 2500
        GIE = 0                          ' no ints during variable update
        DutyHold2 = TempW
        GIE = 1
    SetServo1:
        TempW = Servo1 * 2500
        GIE = 0
        DutyHold1 = TempW
        GIE = 1
    ;----[Dual Servo Driver - Interrupt Service]--------------------------------
    Asm
    myint
        movwf     CCP1CON            ; Set Pins to default state (High)
        clrf      CCP2CON            ; clrf added per Bruce's suggestion
        movwf     CCP2CON
        movf      DutyHold1+1,W      ; update current position's dutycycle
        movwf     CCPR1H             ; for both servos
        movf      DutyHold1,W
        movwf     CCPR1L
        movf      DutyHold2+1,W
        movwf     CCPR2H
        movf      DutyHold2,W
        movwf     CCPR2L
    EndAsm
    Hi Darrel,
    Pretty cool stuff. Have you tested this on other 18F parts? I don't have a 4520 to test
    with, but I couldn't get this to work without clearing CCP1CON before moving 9 to it on
    a 452 or 4431.
    Had to do this;
    MyInt
        clrf CCP1CON         ; 18F452 & 18F4431 require this before it changes CCP1 output
        movlw 9
        movwf CCP1CON
        bcf PIR1,TMR1IF      ; clear TMR1 int flag
        retfie FAST          ; use RETFIE FAST to restore WREG, STATUS & BSR
    On an 18F452 or 18F4431, the above works fine, but only if I clear CCP1CON first.
    This works on a 452 & 4431 with CCP1 & TMR1 ints enabled on any output pin;
    MyInt
        btfss PIR1,TMR1IF    ; TMR1 interrupt?
        bra CCP              ; no - service CCP interrupt
        bcf PIR1,TMR1IF      ; yes - clear TMR1 int flag
        bsf LATB,0           ; set RB0 on TMR1 interrupt
        retfie FAST          ; return
    CCP
        bcf PIR1,CCP1IF      ; clear CCP1 int flag
        bcf LATB,0           ; clear RB0 on compare interrupt
    I was just wondering if this might be a fluke with the 4520 part - since none of the other
    18F parts I've tested will toggle CCP1 with just the movlw 9, movwf CCP1CON?
    Last edited by Bruce; - 14th December 2009 at 02:34. Reason: 2nd version uses CCP1CON = %00001010
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hmmm, very interesting.
    I had not tried it on any other chips, and with the 4520 you definitely don't have to clear it first.
    But I just tried an 18F452, and you are absolutely correct.
    It doesn't work unless you clear the CCPCON register first.
    Very interesting indeed,
    Thanks Bruce.
    Thanks. I was just curious. I had fought with this one before on a servo driver, and just
    couldn't get it to work without both ints enabled, or clearing CCP1CON first.
    I'm thinking it may be due to the huge number of problems Mchip had (see erratas') on
    ECCP & CCP with this one?
    -Bruce
    tech at rentron.com
    Default Re: 16 bit PWM using CCP1
    just tried your "red" code in the isr on a pic18f45k20
    you are right
    bsf INTCON,6 ;PEIE = 1 Enable peripheral interrupts
    bsf PIE1,0 ; TMR1IE= 1 Enable TMR1
    these two lines lock it up. can't see why yet
    it looked harmless but its not ,its much worse than useless
    bsf INTCON,7 ;GIE = 1
    intcon bits 6 and 7 should already be set , setting them again should do no harm
    pie1.0 is also set , setting it again can't hurt
    it just wastes 12 cpu cycles
    the problem lies elsewhere, PWM_VAL must be > 30 ,values from 0-29 wont work could that have happened
    Jun 2009
    Sc*nthorpe, UK
    That is exactly what I thought and could not find anything to indicate otherwise in the datasheet.
    No I started PWM_VAL for zero and incremented up in steps of 1 and it worked all the way rolling over and starting from 0. If 0-29 does not work I could not detect it with my voltmeter.
    Aug 2005
    Michigan, USA
    .... Pulses will be continuous at ~40hz ....
    How do you get ~40-Hz?
    <added>
    Oops! Sorry! I see it. Timer 1 rollover every 26.2144 msecs (38.14697265625 Hz)... I need another cup o' coffee (grin)...
    Nov 2009
    Hi Everyone,
    Talat from Istanbul here. Please help wıth my PWM problem.
    My code is runnıng BUT I get only 1 or 2 output pulses from port B3 on startup then no output after that.
    What am ı doıng wrong?
    Thanks ın advance fo you help.
    Talat
    '* Name : *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 09.08.2014 *
    '* Version : 1.0 *
    '* Notes : 16F1827 *
    ' DEVİCE 16F1827
    __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    __config _CONFIG2, _PLLEN_ON & _LVP_OFF & _LVP_OFF & _STVREN_OFF; & _VCAPEN_OFF
    CLEAR
    DEFINE OSC 32
    OSCCON=%01110000 '32
    DEFINE INTHAND PWM_INT
    PWM_VAL VAR WORD BANK0 SYSTEM
    VALUE VAR WORD
    INIT:
    APFCON0 = 0 'SET PORTB.3 TO CCP1
    T1CON = %00100000 'Prescaler 1:4
    PIE1.0 = 1 'TMR1IE TMR1 Interrupt Enable
    PIR1.0 = 0 'TMR1IF TMR1 Interrupt Flag
    INTCON.7 = 1 'GIE Global Interrupt Enable
    INTCON.6 = 1 'PEIE Peripheral Interrupt Enable
    CCP1CON = 9 'compare mode
    OUTPUT PORTB.3 'CCP PIN
    T1CON.0 = 1 'TMR1ON SET TMR1
    PAUSE 1000
    VALUE=1000
    MLOOP:
    VALUE=VALUE+1
    PWM_VAL = VALUE
    Goto MLOOP
    Asm
    PWM_INT
    movlw 9 ; compare mode
    clrf CCP1CON ; clear reg
    movwf CCP1CON ; Set reg
    movf PWM_VAL+1,W ; hb
    movwf CCPR1H ; put
    movf PWM_VAL,W ; lb
    movwf CCPR1L ; put
    bcf PIR1,0 ; TMR1IF = 0 Clear Timer1 Int Flag
    RETFIE ; Return from Interrupt
    EndAsm
    Nov 2009
    Hi Darrel & Everyone,
    Talat from Istanbul here. Please help with my PWM problem.
    My code is running(?) BUT I get only 1 or 2 output pulses from port B3 on startup then no output after that.
    What am I doıng wrong?
    Thanks in advance fo you help.
    Talat
    '* Name : *
    '* Version : 1.0 *
    ' DEVİCE 16F1827
    CLEAR
    DEFINE OSC 32
    VALUE VAR WORD
    INIT:
    PAUSE 1000
    VALUE=1000
    MLOOP:
    VALUE=VALUE+1
    PWM_VAL = VALUE
    Goto MLOOP
    Asm
    PWM_INT
    movwf CCPR1H ; put
    movf PWM_VAL,W ; lb
    movwf CCPR1L ; put
    EndAsm
    Jun 2009
    Sc*nthorpe, UK
    '* Name : *
    '* Version : 1.0 *
    ' DEVİCE 16F1827
    CLEAR
    DEFINE OSC 32
    VALUE VAR WORD
    INIT:
    PAUSE 1000
    VALUE=1000
    MLOOP:
    VALUE=VALUE+1
    PWM_VAL = VALUE
    Goto MLOOP
    Asm
    PWM_INT
    movwf CCPR1H ; put
    movf PWM_VAL,W ; lb
    movwf CCPR1L ; put
    EndAsm
    Now we know that what you want to do is possible, thanks to Richard. Can anyone work out what is wrong with Talat's code?
    Jun 2009
    Sc*nthorpe, UK
    Talat
    I do not understand why you included the lines in red in you ISR
    '* Name : *
    '* Version : 1.0 *
    ' DEVİCE 16F1827
    CLEAR
    DEFINE OSC 32
    VALUE VAR WORD
    INIT:
    PAUSE 1000
    VALUE=1000
    MLOOP:
    VALUE=VALUE+1
    PWM_VAL = VALUE
    Goto MLOOP
    Asm
    PWM_INT
    movwf CCPR1H ; put
    movf PWM_VAL,W ; lb
    movwf CCPR1L ; put
    EndAsm
    As I do not have a 16F1827 I can not do any testing. But after some thought I used an 18F452 to test your code and it did not work. I then compared data sheets for the 16F1827 and 18F452 and finding no reason for the lines in red I commented them out reprogramed the 18F452 and it ran. But I had to add a pause 10 in the main loop so my voltmeter could display the readings.
    Here is my version
    '* Name : *
    '* Version : 1.0 *
    ' DEVİCE 16F1827
    CLEAR
    DEFINE OSC 32
    INIT:
    PAUSE 1000
    MLOOP:
    PWM_VAL = PWM_VAL+1
    PAUSE 10
    Goto MLOOP
    Asm
    PWM_INT
    movwf CCPR1H ; put
    movf PWM_VAL,W ; lb
    movwf CCPR1L ; put
    EndAsm
    I am very interested to know if my version works on the 16F1827 that you have.
    Nov 2009
    Yes, you're right.
    My first version was like you, did not work. To better understand the problem I have added including red lines.
    I tried again and the result is the same version. In the start-up process produces two pulses and then stops.
    the 30 figure came from the pic16f1825 using dt_ints14
    for a pic18f45k20 the figure is 25 using dt_ints18
    for a pic18f45k20 using DEFINE INTHAND the figure is 11
    seems dt_ints introduces more latency
    point is 0 is not off and pwm < latency is not a small pw
    the code in red just wastes time ,it's not what stopped the program from working . the problem is the changing sfr's in the wrong bank.
    Jun 2009
    Sc*nthorpe, UK
    It did stop it working on my 18F452 though.
    Hi, Talatsahim
    First have a look to how PBP shares its variables with asm ...
    Quote Originally Posted by Acetronics2 View Post
    Hi, Talatsahim
    _WhatsThat ?
    For starters, There is NO 16 bit compare register for PWM use. The upper byte is shared with a few other bits of config. There is ONLY 10 bit's available for PWM use in hardware. Read the data sheet for the processor you are using.
    EN82fn
    Nov 2009
    Thanx Dave,
    I use 10 bit hardware PWM. But I need more resulation. I such a little trick
    Talat
    What Acetronics2 is trying to say is, when accessing PBP variables inside of an ASM routine you need to prefix an underscore before the variable name such as "movf _PWM_VAL,W ; lb"
    As far as getting more resolution from the PIC processor, Your out of luck. You can always build your own digital pwm circuit with hardware if you are so inclined.
    EN82fn
    Nov 2009
    Hi, Acetronics2
    This is part of code. Variable sharing, what is wrong?
    Thanx
    in dt's code the var is declared in a asm routine and as EXT in pbp
    @wDUTY = CCPR1L
    if you declare a var in pbp and wish to refer to it in asm it must be prefixed with an underscore as others have stated
    Jun 2009
    Sc*nthorpe, UK
    That is from post #1 but in #3 which Talat is using
    is the way they are declared and again "_" is not used.
    Jun 2009
    Sc*nthorpe, UK
    Found the answer in the manual of all places!
    Modifiers can be used to specify certain attributes of the variable when created:
    address A numeric address may be used as a modifier. This instructs PBP where to locate the variable in RAM.
    BANKx Instructs PBP to locate the variable in a specific bank of RAM.
    SYSTEM The default behavior of PBP is to append a prefix underscore character when creating the variable in Assembly Language. The SYSTEM modifier inhibits this behavior so that the variable name will be identical in PBP code and Assembly code.
    Does anyone read the manual, me included obviously?
    when all else fails
    I'm trying to get this idea to fly on a 16f1825
    the code when converted to C works fine (I get a nice pwm waveform at 60.85 hz)
    but it won't fly with pbp3 yet
     * File:   newmain.c
     * Author: richard
     * Created on 23 August 2014, 7:25 PM
    #include <xc.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    // #pragma config statements should precede project file includes.
    // Use project enums instead of #define for ON and OFF.
    // CONFIG1
    #pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
    #pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
    #pragma config PWRTE = ON       // Power-up Timer Enable (PWRT enabled)
    #pragma config MCLRE = ON       // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
    #pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
    #pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
    #pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
    #pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
    #pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
    #pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
    // CONFIG2
    #pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
    #pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
    #pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
    #pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
    #pragma config LVP = OFF        // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
    typedef unsigned char byte;
    #define bit_time 100    //   9600 ok @8mhz
    #define serout_pin PORTAbits.RA0
    #define _XTAL_FREQ 32000000
    void send_serial( char data);
    void ser_str(char *buff);
    byte prnb[20];
    uint16_t duty;
    void main(void) {
       OSCCON=0X70;
       ANSELA=0;
       ANSELC=0;
       TRISA = 0b001110;
       TRISC=0b11111001;
       PORTA=255;
        __delay_ms(2000);
       T1CON   = 0b00000000 ;
        PIE1    = 0b00000001;
         INTCON  = 0b11000000;
        CCP4CON = 0b00001001;
        duty = 32768 ;
        CCPR4H=duty>>8;
         CCPR4L=duty;
                T1CONbits.TMR1ON=1;
       strcpy(prnb,"ready");
    ser_str(prnb);
    INTCON=0xc0;
    while(1){
       strcpy(prnb," loop ");
       ser_str(prnb);
       sprintf(prnb,"%4x",duty) ;
       duty+=200;
       ser_str(prnb);
       CCPR4H=duty>>8;
       CCPR4L=duty;
       __delay_ms(2000);
        return;
    void interrupt ISR (void) {
        CCP4CON=0;
        CCP4CON=9;
        PIR1bits.TMR1IF=0;
        PORTCbits.RC2=!PORTCbits.RC2; // just to check interrupt
    void send_serial( char data){  // bit_time 200us 4800 baud ,100 us 9600 ,400us 2400 (NOT INVERTED)
      uint8_t i;
      i=8;                            // 8 data bits to send
     // di();
      serout_pin = 0;                // make start bit
       __delay_us(bit_time);
      while(i)                        // send 8 serial bits, LSB first
        if(data&1) serout_pin = 1;  // invert and send data bit
        else   serout_pin  = 0;
        data >>=1 ;//(data >> 1);           // rotate right to get next bit
        i--;
           __delay_us(bit_time);           // wait for baud
      serout_pin  = 1;                // make stop bit
      // ei();
    void ser_str(char *buff){
     char k = strlen(buff);
           for (int j=0;j< k;j++){
           send_serial(buff[j]);
    a warning to anybody trying to use this idea , its not fool proof and apart from the limitations as described by henrik its a bit risky too.
    if you try to set the pwm duty below the number of timer ticks taken up during the interrupt latency the pwm pin will be driven high and may cause unexpected results
    my tests indicate a minimum pwm duty of 30
    caveat emptor
    your version cannot work since CCP1CON and CCPR1H are not in bank 0
    and yes the code you marked red serves no purpose in the given example
    Jun 2009
    Sc*nthorpe, UK
    My point was that the code in red stopped it working and I could not work out why it was there.
    Nov 2009
    Richard,
    Thanks for your reply.
    Yes, you're right. 103 error occurs after compiling. Banksel command is used, will you?
    Talat
    Nov 2009
    I installed the PBP trial version 3.0.7 to try. Nothing's changed. Error 113 continues (Post 56, I wrote 103, it's wrong)
Size:  60.1 KBName:  16b.png
    Check your spelling of CCPR1H and CCPR1L.
    Nov 2009
    Henrik, congratulations for being careful, thank you.
    This is a completely copy-paste disaster
    Talat
    Last Post: - 14th June 2016, 07:55
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:44
    Last Post: - 6th March 2005, 01:07
