A pbp version
Code:'**************************************************************** '* Name : PWM16.BAS * '* Author : RICHARD * '* Notice : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 8/23/2014 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** #CONFIG __config _CONFIG1, _FOSC_INTOSC & _CP_OFF & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CLKOUTEN_OFF __config _CONFIG2, _PLLEN_ON & _LVP_OFF #ENDCONFIG include "dt_ints-14.bas" asm INT_LIST macro INT_HANDLER TMR1_INT, _Tm1, asm,yes endm INT_CREATE ENDASM DEFINE OSC 32 sSEROUT_PIN VAR PORTA.0 sBAUD CON 84 '16416 = 19200 BAUD yTEMP VAR Byte wDUTY VAR WORD '*********************************************** START: ' disable analog functions OSCCON=$70 ANSELA=0 ANSELC=0 '******************** '16 BIT CCP1 PWM T1CON = 0 ' Turn off Timer1 with a Prescaler value of 1:8 PIE1 = %00000001 ' enable TMR1 overflow interrupt INTCON = %11000000 ' enable global and peripheral interrupts ' LOW PORTC.2 ON MATCH TM1 WITH DUTY ccp4con=0 wDUTY = 32768 ' 32768 = 50% DUTY PWM T1CON.0 = 1 ' TMR1 ON CCPR4H=$80; CCPR4L=0; PAUSE 800 SerOut2 sSEROUT_PIN,sBAUD,["START",13] trisc = %11111001 '*********************************************** CCP4CON = %00001001 MAIN: yTEMP = yTEMP +1 SerOut2 sSEROUT_PIN,sBAUD,["LOOP ",Dec yTEMP,13] PAUSE 500 Goto MAIN '**** ASSEMBLY INTERRUPT ROUTINE **** Tm1: Asm bsf PORTC ,2 CHK?RP CCP4CON clrf CCP4CON movlw 9 movwf CCP4CON banksel 0 bcf PORTC ,2 EndAsm '**** END ASSEMBLY INTURRUPT ROUTINE **** @ INT_RETURN End
