PICBasic newbie problem
Results 1 to 33 of 33
Threaded View
    Feb 2008
    Question PICBasic newbie problem
    Dear members,
    FOA,I'm not new to the PIC World, I'm using CCS C compiler regularly
    Recently I started using PICBasic Pro because i knew basic is easy to use when it come create very simple project... you know leds stuff!
    However after reading that @ __config is depreciated for PIC18
    I'm trying to use CONFIG instead but how ?
    CONFIG FOSC = HS,LVP = OFF,BOR = OFF,MCLRE = OFF
    led VAR PORTB.5
    steps VAR WORD
    cycles CON 2
    ' Change limits for steps to play around 0 or 100% brightness
    ' Change steps for different duration of ramps
    ' Works good even with high brightness LEDs, harder to control linearly
    fade:
    up:
    For steps=0 TO 255
    PWM led,steps,cycles
    Next
    High led
    Pause 2500
    down:
    For steps=255 TO 1 STEP -1
    Next
    Low led
    Pause 2500
    GoTo fade
    Microcode studio says ERROR syntax at the first line! why ?
    Yes i did read the other post, including the faq about headers but like i said __CONFIG dont work anymore with MPASM
    Best Regards,
    Laurent
    EDIT: oh btw , pic18f4550 with 12mhz hs xtal
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Picbasic Newbie Problem
    By Stargazer3141 in forum mel PIC BASIC
    Last Post: - 21st August 2007, 18:40
  3. Problem on writing EEPROM in Winpic800 with picbasic pro
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 17:33
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  5. DMX & PicBasic coding problem
    By magicmarty in forum mel PIC BASIC Pro
    Last Post: - 20th September 2004, 16:35
