16 bit PWM using CCP1
Results 1 to 40 of 61
    Default Re: 16 bit PWM using CCP1
    in dt's code the var is declared in a asm routine and as EXT in pbp
    wDUTY VAR WORD EXT ' map wDuty to CCPR1L:H as a word
    @wDUTY = CCPR1L
    if you declare a var in pbp and wish to refer to it in asm it must be prefixed with an underscore as others have stated
    Jun 2009
    Sc*nthorpe, UK
    That is from post #1 but in #3 which Talat is using
    DutyHold1 VAR WORD BANK0 SYSTEM      ' holds next dutycycle, synch with PWM
    DutyHold2 VAR WORD BANK0 SYSTEM      '
    is the way they are declared and again "_" is not used.
    Jun 2009
    Sc*nthorpe, UK
    Found the answer in the manual of all places!
    Modifiers can be used to specify certain attributes of the variable when created:
    address A numeric address may be used as a modifier. This instructs PBP where to locate the variable in RAM.
    BANKx Instructs PBP to locate the variable in a specific bank of RAM.
    SYSTEM The default behavior of PBP is to append a prefix underscore character when creating the variable in Assembly Language. The SYSTEM modifier inhibits this behavior so that the variable name will be identical in PBP code and Assembly code.
    Does anyone read the manual, me included obviously?
    when all else fails
    Last Post: - 14th June 2016, 08:55
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
