16 bit PWM using CCP1
Results 1 to 40 of 61
    Yup, that's what mister-e's calculator says with 40mhz, 1:1, and 16-bit. 152 hz.
    The PIC18F2331/2431/4331/4431 series has a bunch of 14-bit PWM modules. But they are completely different from the CCP module.
    Bruce has done a few examples, but I don't think any of them were for music.
    best regards,
    PIC18F2331/2431/4331/4431:
    FOSC 40 MHz
    MIPS 10
    PWM Resolution 14 bits
    PWM Frequency 2.4 kHz
    14 bit to slow for CD quality music.
    10 bit sounds good though.
    A dsPIC would be ideal.
    On my first post my code included saving the state of the critical registers.
    Would this be required in a longer program?
    Norm
    Maybe you'd be better off with an R2R network as a Digital to Analog Converter.
    Something like what Steven Wright did here (Not PBP).
    SDMMCWavPlayer
    http://www.sfcompiler.co.uk/wiki/pmw...SDMMCWavPlayer
    And no, you won't need to save STATUS, WREG and BSR, unless you start using Low Priority interrupts.
    The Shadow registers automatically save and restore them in hardware for High priority ints on 18F's.
    R2 ladder done here PIC iPod wav player
    Now would like to port to PBP a basic PWM low pin count low part count wave player.
    The code is 8,069 program bytes possibly less if optimized.
    Are their < 28 pin 18F PICs supported by compiler 2.50C?
    Norm
    Last Post: - 14th June 2016, 08:55
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
