I2C CONFUSION, Help needed please
Results 1 to 40 of 43
    Nov 2007
    West Covina, CA
    Default Re: I2C CONFUSION, Help needed please
    Ahhhh... okay
    Let's use this info then. Looks like the address is using bits 1~7 and the Read/Write control bit is 0.
    If control bit is set (=1) then Read, if bit cleared (=0) then Write
    So:
    %00110111 = $37 ' Read function
    %00110110 = $36 ' Write function
    Try that.
    By the way, the device sends the ACK, or acknowledges, by holding the Data line LOW on the 9th clock cycle. The PIC will see this and continue to send data.
    Louie
    Quote Originally Posted by LinkMTech View Post
    How do I implement this, like this below?
    High Led : Pause 500: Low Led : PAUSE 500
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,LOC
    	Addr=$37 : pause 10                    ' OR If SDA=1 then main
    	I2CREAD SDA,SCL,loc,[VALUE],Fail
    	PAUSE 25
    	DEBUG  HEX Value,13,10
    	PAUSE 250
    	DEBUG "Done....",13,10
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Nov 2007
    West Covina, CA
    Just notice the address missing on the Read function.
    Moved the Fail label after Write to test this part first. This will let you know if the Write address was recognized so the Pause 10 is not needed.
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,LOC, Fail  ' Test here first
    	Addr=$37 ': pause 10                    ' OR If SDA=1 then main
    	I2CREAD SDA,SCL,ADDR,loc,[VALUE] ',Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Louie
    Checked it. It fails on the first write statement.
    Fails on the second statement if I swap the values of Addr. i.e. First $37, second Addr $36. First one goes fine.
    Nov 2007
    West Covina, CA
    Okay let's fix that first.
    Put brackets around the Loc as shown in the PBP manual to see if that helps.
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,[LOC],Fail  ' Test here first
    	I2CREAD SDA,SCL,ADDR,[LOC,VALUE] ',Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Louie
    Default Reaching there
    I did exactly the same as above and the sequence completed fine. BUT the values are not consistent with the datasheet, I should get '$2E' from location 0, but WHATEVER location I try to read, I am getting '$FF'
    Default Update
    Have a look at my real term serial monitor. I am actually getting a lot of unexpected data which I don't understand how is getting stored in just one byte. Though among all this, I can see '2E' (but it is swapped around so 'E2'). Note sure if I am trying to convince myself or the data is rubbish.
    I would have thought:
    %00000001 = $37 ' Read function
    %00000000 = $36 ' Write function
    I don't see in this datasheet where you get the rest.
    Default Soooooo Close
    I just discovered, that the I am actually receiving only 1 byte as expected. Rest are just "Start......"13,10 and "Done",13,10. Yesterday got too exhausted and missed this mistake of mine.
    Here is the current code with
    Start:
    Loc=0
    Start_Again:
    	I2CWRITE SDA,SCL,$36,[LOC],Fail1
    	Value=0
    	I2CREAD SDA,SCL,$37,[VALUE] ,Fail2
    	PAUSE 250
    	DEBUG  Value
    	Loc=Loc+1
    	If Loc<4 then Start_Again		' Read first 4 locations
    	x=0
    WHILE !Change			' Stay here if Change Stays High
    		 Pause 500  : x=x+1
    		If x =10 then
    			LOC=3 : Goto Main ' Do another read
    		Endif
    WEND
    while Change : pause 100 : wend	' Stay here if change is Low
    Goto Start
    Fail1:					' Try Write again
    	For x=0 to 50
    		High Portc.2 : Pause 50 : Low PortC.2 : Pause 50
    	Next x
    Goto Start_again
    Fail2:					' Try read again
    	For x=0 to 5
    		High Portc.2 : Pause 250 : Low PortC.2 : Pause 250
    	Next x
    Goto Main
    Every time Change line goes low (detected something), I try to read first 4 memory locations. The communication fails a lot of times (both write and read (write more than read) )in this attempt but I do get the data on the screen finally. Secondly, the data which comes is wrong. For example, memory locations 0 does not read 2E for a start.
    Default Re: Soooooo Close
    Success but with one question.
    Finally, I put 20MHz clock. It started working with absolutely no problems.
    This leaves me with one MAJOR question - Is there any way, I can run the whole show at 4MHz, any settings I missed or anything I can do. I have got no extra pins on my PIC to put an external oscillator, I want to confirm the answer to this question before I start again and choose another suitable PIC. My task will get much much easier if there is a way to run it at 4 Sweet Megahertz.
    Many many many thanks to you guys for trying to helping me out on this. This forum is the best.
    16F688 can go up to 8MHz on internal oscillator.
    I'd try that before changing PIC.
    Nov 2007
    West Covina, CA
    I put a test circuit together on my LAB-X4 using the PIC16F688 to talk to a 128kB FRAM.
    I could feel your pain when trying to make your test program work so decided to start from almost scratch.
    The TRIS statements were missing some bit assignments which are not a good thing, from what I read somewhere here by Henrik Olssen, so I put them in.
    The order of CONFIG's and other setups were rearranged as well. Not really sure which fixed it but,
    The end results were that it works at 4MHz and here's the program to compare with.
    ' This setup uses a PIC16F688 and a FM24V01, 128kB Nonvolatile RAM to test
    ' the I2CREAD/WRITE functions at 4MHz.
    ' First: The FRAM memory is loaded with values 1~5 starting from
    ' location 0 using Word size address. The values written are sequentially
    ' loaded into the next memory location, so only the starting address is
    ' needed for this test.
    ' Read address = $A0
    ' Write address = $A1
    ' Second: The FRAM memory locations 0 thru 4 are READ in a loop then stops
    ' and waits the Test button on the LAB-4X to be pushed and repeats.
    ' The data was monitored with the Saleae Logic scope.
    ' Max clock speed measured at 4Mhz was 29kHz
    ' The DEBUG function was not used during this test
    ifdef PM_USED
    device pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    PORTA=0
    PORTC=0
    TRISA = %00001000   ' All 8 bits assigned one way or the other
    TRISC = %00000000   ' All 8 bits assigned one way or the other
    CMCON0 = 7
    ANSEL = 0
    OPTION_REG = 128    ' PORTA pullups disabled
    INTCON=128
    OSCCON = %01100001  ' Oscillator set to 4MHz
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 1
    Include "modedefs.bas"
    Value       VAR BYTE
    WR_Addr     VAR BYTE
    RD_Addr     VAR BYTE
    LOC         VAR WORD    ' FRAM address must be sent as Word size
    x           VAR BYTE
    SCL     VAR PORTA.4     ' RA4, pin #3
    SDA     VAR PORTA.5     ' RA5, pin #2
    Change  VAR PORTA.3     ' Push button on LAB-X4
    LED     VAR PORTA.0     ' Test LED. LOW = ON
    LOC = 0             ' Start at 0
    LED = 1             ' Turn LED OFF
    PAUSE 1000          ' Give me a chance to start the monitor
    GOSUB Load_Mem      ' Load FRAM memory locations 0~4 with values 1~5
        FOR LOC = 0 TO 4
            LED = 0     ' Turn ON LED, scope monitored
            I2CWRITE SDA,SCL,$A0,[LOC],Fail1
            PAUSEUS 25  ' Paused to see on display
            I2CREAD SDA,SCL,$A1,[VALUE],Fail2
            PAUSEUS 500 ' Paused to seperate packets, viewing purpose only
            LED =1      ' Turn OFF LED
        NEXT LOC
    WHILE CHange: WEND  ' Wait until button pushed
    PAUSE 500           ' Cheap debounce
    GOTO Main
    '----------------------- Fail routines -------------------------------
    	FOR x=0 to 50
    		LOW LED : PAUSE 50 : HIGH LED : PAUSE 50
    	Next x
    GOTO Main
    	For x=0 to 5
    		LOW LED : PAUSE 250 : HIGH LED : PAUSE 250
    	Next x
    GOTO Main
    '---------------------- Load FRAM --------------------------------------
    Load_Mem:
        I2CWRITE SDA,SCL,$A0,[LOC,1,2,3,4,5],Fail1
        LED = 1     ' Turn OFF LED
    This first screenshot is from:
    Load_Mem:
    The 2nd and 3rd from the first and last loop Reads showing the values 1 and 5 after the $A1 READ address.
    Louie
    Nov 2007
    West Covina, CA
    Default ADDICTION, Help needed please
    Okay decided to try the Debug and got fancy while I was at it. This can be addicting!
    Here's the updated code...
    ' The DEBUG function was used this time.
    ifdef PM_USED
    PORTA=0
    PORTC=0
    CMCON0 = 7
    ANSEL = 0
    INTCON=128
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 19200
    DEFINE DEBUG_MODE 1
    Manf        VAR BYTE[3]
    Value       VAR BYTE
    x           VAR BYTE
        FOR LOC = 0 TO 4
            DEBUG "LOC = ", DEC LOC,", ","Value = ", DEC Value,13,10
        NEXT LOC
        DEBUG 13,10 ' Add a space between readings
    '   Send Reserved Slave ID $F8 and address
        I2CWRITE SDA,SCL,$F8,[$A1],Fail1
    '   Send Reserved Slave ID $F9 and address then read in 3 bytes
        I2CREAD SDA,SCL,$F9,$A1,[Manf[0], Manf[1], Manf[2]],Fail2
    '   Debug Manufacture and Product ID. This FRAM = 00x41x00
        DEBUG "Manf, & Product ID = ",HEX2 Manf[0],",",HEX2 Manf[1],",",_
        HEX2 Manf[2],13,10,13,10
    GOTO Main
    	FOR x=0 to 50
    	Next x
    GOTO Main
    	For x=0 to 5
    	Next x
    GOTO Main
    Load_Mem:
    Now the Debug at 19.2k..
    Louie
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 01:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 11:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 10:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 16:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 21:24
