Tried this:
Didn't worked. (Value/Addr/Loc = Byte size)Code:Pause 500 DEBUG "Start......",13,10 Value=0 Addr=$9B Loc=0 Main: High Led : Pause 500: Low Led : PAUSE 500 I2CWRITE SDA,SCL,ADDR,LOC Addr=$1B : PAUSE 50 I2CREAD SDA,SCL,ADDR,LOC,[VALUE],Fail PAUSE 25 DEBUG HEX Value,13,10 PAUSE 250 DEBUG "Done....",13,10 WHILE 1 : WEND Goto Main Fail: toggle portc.2 goto main
Can I not the Micro at 4MHz? The Datasheet says MAX speed is 400KHz, so I assume lower speeds are supported. Am I right?
