I2C CONFUSION, Help needed please
Results 1 to 40 of 43
    Default Re: I2C CONFUSION, Help needed please
    My Code is this:
    Include "modedefs.bas"
    ifdef PM_USED
    device pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_ON & _CPD_ON & _BOD_ON & _IESO_ON & _FCMEN_ON
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 1
    DEFINE I2C_SLOW 1
    'DEFINE I2C_HOLD 1
    PORTA=0
    PORTC=0
    TRISA = %000100
    TRISC = %110000
    CMCON0 = 7
    ANSEL = 0
    OPTION_REG = 128
    INTCON=128
    Value Var word
    SCL Var PortC.5
    SDA Var PortC.4
    Change Var PortA.2
    LED Var PortC.0
    Pause 500
    DEBUG "Start......",13,10
    value=0
    High Led : Pause 1000: Low Led : PAUSE 1000
    I2CREAD SDA,SCL,$1B,0,[VALUE],Fail
    PAUSE 25
    DEBUG HEX Value,13,10
    PAUSE 250
    DEBUG "Done....",13,10
    Goto Main
    Fail:
    toggle portc.2
    PortC.2 keeps toggling along with normal LED.
    I have also attached the device datasheet. I really appreciate the help in this.
    From PBP manual about I2CREAD:
    "Constants should not be used for address..."
    Don't know if this can help.
    I added two bytes - Addr & Loc
    Addr=$1B
    Loc=0
    Sent - I2CREAD SDA,SCL,Addr,Loc,[Value],Fail
    No Luck
    What is also confusing me is the control byte in the manual, the device datasheet does not mention any control byte.
    I have an address $1B which I am sending as control and location in the device is being sent as Address according to the manual.
    I thought I saw 9 bits used from control in the datasheet you linked.
    Maybe you're supposed to use a word and ignore the other 7 bits? Or that could be handled by PBP for I2C?
    Do you get only a byte back, word, multiple bytes?
    Your circuit does make address 0 right?
    (just throwing ideas at you)
    Steps Taken:
    1) Configuration changed: _INTRC_OSC_NOCLKOUT
    2) Made 16f688 run at 8MHz : OSCCON=%01110001
    3) Commented DEFINE I2CSLOW 1
    4) Value changed to BYte (then to word again)
    I get a byte back from the device (from what I have understood). Yes there is an address 0 in the device. I should get back chip ID i.e-'2E' as per the datasheet.
    Still no Luck.
    Nov 2007
    West Covina, CA
    I couldn't find detailed info on the Write/Read bit of the device address. But I will guess it is bit 7.
    You need to Write to the device first using the address with the "Write" bit set.
    $1B or %00011011 becomes $9B or $10011011
    Without confirming the proper syntax of the commands, here's something off the top of my noodle:
    This will cover steps 1~4 of Section 4.3.2 of the datasheet
    I2CWRITE SDA,SCL,[Addr,Loc,]  ' Addr plus Write bit = $9B
    This will cover steps 5~7 of Section 4.3.2 of the datasheet
    I2CREAD SDA,SCL,[Addr,Loc]   ' Addr plus Read bit = $1B
    Putting it together should get you moving in the right direction.
    Here's a note to myself that might come in handy too:
    Last edited by LinkMTech; - 27th July 2013 at 17:53. Reason: Added I2C screen shot notes
    Louie
    Tried this:
    Pause 500
    Value=0
    Addr=$9B
    Loc=0
    High Led : Pause 500: Low Led : PAUSE 500
    	I2CWRITE SDA,SCL,ADDR,LOC
    Addr=$1B : PAUSE 50
    	I2CREAD SDA,SCL,ADDR,LOC,[VALUE],Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Didn't worked. (Value/Addr/Loc = Byte size)
    Can I not the Micro at 4MHz? The Datasheet says MAX speed is 400KHz, so I assume lower speeds are supported. Am I right?
    Nov 2007
    West Covina, CA
    Remove the PAUSE 50 after I2CWRITE because the device starts sending immediately if its happy.
    Then try bit 6 then 5 instead for the Write bit if the Write bit position was a wrong guess.
    Bit 6 = $5B
    Bit 5 = $3B
    Louie
    May 2008
    Italy
    The device you are using is a fast mode device (400 khz) so you have to remove the "DEFINE I2C_SLOW 1" and very likely you have to increase your clock speed (4 MHz could be too slow). Also change the variable into byte (you are using word).
    Good luck
    Al.
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 02:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 12:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 11:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 17:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 22:24
