I2C CONFUSION, Help needed please
Results 1 to 40 of 43
    Default Re: I2C CONFUSION, Help needed please
    OSCCON changed to set 4MHz, internal oscillator.
    I2CSLOW 1 stays commented
    I2CHOLD 1 stays commented
    LED 	Var PortC.0
    Value Var 	Byte
    Addr	Var	Byte
    Loc 	Var	Byte
    Pause 500
    	DEBUG "Start......",13,10
    Value=0
    Addr=$9B 'Tried $3B,$5B
    Loc=0
    High Led : Pause 500: Low Led : PAUSE 500
    	I2CWRITE SDA,SCL,ADDR,LOC
    	Addr=$1B
    	I2CREAD SDA,SCL,ADDR,LOC,[VALUE],Fail
    	PAUSE 25
    	DEBUG  HEX Value,13,10
    	PAUSE 250
    	DEBUG "Done....",13,10
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    No Luck
    > It is bit 7 for R/W (Slave address + write bit)
    Nov 2007
    West Covina, CA
    How did you find that?
    Louie
    Picked up from the datasheet of the device. That is what I understood, am I wrong?
    Though I did tried $3B & $5B.
    Nov 2007
    West Covina, CA
    Not sure if you're wrong or not. I'm still trying to decipher that part in the datasheet because they don't make it easy. I've found that some information has to be gleaned from other devices of the same manufacturer to put the whole story together, kinda sucks!
    I also noticed the address stays at $1B after the first loop in your test program and if it works you might miss it.
    Note: I just found one of my programs on another I2C device that has bit 1=0 as the Write bit.
    $1B = $00011011 used for Read
    $1A = $00011010 used for Write
    Louie
    I read it again to confirm this, the attachment is my source. It also mentions 9 bits long address. Not sure who sends an ack. I see that in read statement the device send ack, so why add it to the address PIC is sending. Very confusing.
    Nov 2007
    West Covina, CA
    Ahhhh... okay
    Let's use this info then. Looks like the address is using bits 1~7 and the Read/Write control bit is 0.
    If control bit is set (=1) then Read, if bit cleared (=0) then Write
    So:
    %00110111 = $37 ' Read function
    %00110110 = $36 ' Write function
    Try that.
    By the way, the device sends the ACK, or acknowledges, by holding the Data line LOW on the 9th clock cycle. The PIC will see this and continue to send data.
    Louie
    Quote Originally Posted by LinkMTech View Post
    How do I implement this, like this below?
    	Addr=$36
    	Addr=$37 : pause 10                    ' OR If SDA=1 then main
    	I2CREAD SDA,SCL,loc,[VALUE],Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    I would have thought:
    %00000001 = $37 ' Read function
    %00000000 = $36 ' Write function
    I don't see in this datasheet where you get the rest.
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 01:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 11:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 10:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 16:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 21:24
