DIV32 confusion
Results 1 to 5 of 5
Thread: DIV32 confusion
    Default DIV32 confusion
    Heres my code, (values taken from the PBPro manual to try and make it work)
    s_const VAR WORD
    v_raw VAR WORD
    s_const = 500*1000 's_const should equal 500000 internally
    v_raw = DIV32 100 'v_raw should equal 5000
    SEROUT2 s_pin, baud, [DEC5 v_raw] 'should display 5000 on my serial LCD
    instead of 5000 being displayed, I get 65535.
    I'm not using interrupts, but I tried this with DISABLE/ENABLE with the same result.
    I know I'm missing something obvious, but can anyone help? I really did read the manual!
    Feb 2004
    Michigan, USA
    Missing lo.V_raw and hi.V_raw?? lo holds the lower 8 bits and hi holds the higher 8 bits.
    Default answered my own question...duh!
    Apparently, you must use a word variable to generate the 32 bit result
    add to my original code
    a VAR WORD
    b VAR WORD
    a=500
    b=1000
    and change to
    v_raw=a*b
    and it works as advertised
    jmgelba thanks for prompt reply but if I understand correctly DIV32 is working with words, not bytes.
    When you multiply 2 constants together, they are actually multiplied at compile time. So, s_const = 500*1000 doesn't load the registers like you need it to.
    At least 1 of the numbers needs to be a WORD sized variable.
    <br>
    Default Thanks Darrel
    now I can save a word!
  1. Problem with Div32
    Last Post: - 22nd April 2008, 03:54
  2. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 05:33
  3. Div32
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2007, 21:26
  4. 32-bit Variables and DIV32, Hourmeter 99999.9
    Last Post: - 23rd November 2006, 08:23
  5. Retrieving Div32 Remainder
    Last Post: - 20th August 2003, 04:53
