I2C CONFUSION, Help needed please
Results 1 to 40 of 43
    Exclamation I2C CONFUSION, Help needed please
    I am trying to communicate with an I2C device. I have done almost everything I could think of but it is not working. The manual mentions stuff but not exactly matching with the datasheet of the device. The device datasheet mentions something about ACK/NACK which the pbp manual does not mention even once. On top my lack of understanding of I2C has left me with no other option to ask here about what I am doing wrong.
    What I have done:
    I have tried the following commands:
    Value var byte
    I2CREAD SDA,SCL,%000110100,0,[Value] ' Tried this
    I2CREAD SDA,SCL,$1B0,0,[Value] ' Tried this
    I2CREAD SDA,SCL,$1B,0,0,[Value] ' Tried this
    Then When I do this:
    debug HEX Value ' I am expecting '2E' on my screen. But I am not getting it.
    (Location Zero will read 2E in the device)
    I attach the section explaining the I2C from the datasheet. The device address is $1B.
    Many thanks in advance
    (Using 16F688 @ 4 MHz)
    Miami, Florida USA
    Default Re: I2C CONFUSION, Help needed please
    Did you put the two pull-up 4.7k resistors in the SDA and SCL lines?
    Anonymous
    Miami, Florida USA
    Also, you don't need to worry about anything that you highlighted in red. The I2CREAD and I2CWRITE commands take care of that for you.
    Anonymous
    Yes, pull ups are there @ 3.2k.
    I tried the statement : I2CREAD SDA,SCL,$1B,0,[VALUE] (is it correct? because I don't had any luck)
    My Code is this:
    Include "modedefs.bas"
    ifdef PM_USED
    device pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_ON & _CPD_ON & _BOD_ON & _IESO_ON & _FCMEN_ON
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 1
    DEFINE I2C_SLOW 1
    'DEFINE I2C_HOLD 1
    PORTA=0
    PORTC=0
    TRISA = %000100
    TRISC = %110000
    CMCON0 = 7
    ANSEL = 0
    OPTION_REG = 128
    INTCON=128
    Value Var word
    SCL Var PortC.5
    SDA Var PortC.4
    Change Var PortA.2
    LED Var PortC.0
    Pause 500
    DEBUG "Start......",13,10
    value=0
    High Led : Pause 1000: Low Led : PAUSE 1000
    I2CREAD SDA,SCL,$1B,0,[VALUE],Fail
    PAUSE 25
    DEBUG HEX Value,13,10
    PAUSE 250
    DEBUG "Done....",13,10
    Goto Main
    Fail:
    toggle portc.2
    PortC.2 keeps toggling along with normal LED.
    I have also attached the device datasheet. I really appreciate the help in this.
    From PBP manual about I2CREAD:
    "Constants should not be used for address..."
    Don't know if this can help.
    I added two bytes - Addr & Loc
    Addr=$1B
    Loc=0
    Sent - I2CREAD SDA,SCL,Addr,Loc,[Value],Fail
    No Luck
    What is also confusing me is the control byte in the manual, the device datasheet does not mention any control byte.
    I have an address $1B which I am sending as control and location in the device is being sent as Address according to the manual.
    May 2008
    Italy
    The device you are using is a fast mode device (400 khz) so you have to remove the "DEFINE I2C_SLOW 1" and very likely you have to increase your clock speed (4 MHz could be too slow). Also change the variable into byte (you are using word).
    Good luck
    Al.
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 01:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 11:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 10:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 16:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 21:24
