Problems with mpasm
Results 1 to 34 of 34
Threaded View
  1. #11
    Jun 2008
    Varese , Italy
    Default mpasm and Melabs Floating Point
    I still have a problem compiling with MPASM a picbasic program that includes Melabs floating point.
    The program is attached to the message.
    The error list that appears to me using Mpasm and the pic18f452 is here:
    Executing: "c:\pbp_250\PBPW.EXE" -ampasmwin -oq -z -p18F452 "452_9912_3.pbp"
    PICBASIC PRO(TM) Compiler 2.50, (c) 1998, 2007 microEngineering Labs, Inc.
    All Rights Reserved.
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 805 : Symbol not previously defined (flo3232)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 1222 : Symbol not previously defined (flo3232)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 1411 : Symbol not previously defined (flo3232)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 1895 : Symbol not previously defined (flo3232)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2369 : Symbol not previously defined (fsr)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2376 : Symbol not previously defined (indf)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2377 : Symbol not previously defined (indf)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2379 : Symbol not previously defined (indf)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2381 : Symbol not previously defined (indf)
    Error[113] D:\PRJ_ACTIVE\452_9912_3.ASM 2382 : Symbol not previously defined (fsr)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2386 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2386 : Illegal opcode (_binary)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2387 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2387 : Illegal opcode (_binary)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2388 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2388 : Illegal opcode (_binary)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2389 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2389 : Illegal opcode (_binary)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2390 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2390 : Illegal opcode (_bcd)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2391 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2391 : Illegal opcode (_bcd)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2392 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2392 : Illegal opcode (_bcd)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2393 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2393 : Illegal opcode (_bcd)
    Warning[207] D:\PRJ_ACTIVE\452_9912_3.ASM 2394 : Found label after column 1. (rlf)
    Error[122] D:\PRJ_ACTIVE\452_9912_3.ASM 2394 : Illegal opcode (_bcd)
    Loaded D:\prj_active\452_9912_3.COD.
    BUILD SUCCEEDED: Wed Jul 02 18:07:22 2008
    Any suggestion ?
    Thank you
    regards,
    Ambrogio
    IW2FVO
    Have you disabled case sensitivity in MPASM? This can cause a lot of odd problems.
  1. Moved from PM to MPASM and have fuse definition problems
    Last Post: - 26th November 2008, 23:27
  2. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  3. MPASM 18F4550 getting started
    Last Post: - 5th September 2007, 00:59
  4. MPASM problems
    Last Post: - 31st August 2007, 02:29
  5. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
