MPASM problems
Results 1 to 5 of 5
Thread: MPASM problems
Threaded View
    Default MPASM problems
    I am using MCSP 3.0.0.0. with PBP 2.47 and use a Melabs USB serial programmer or EPIC to load the MCS bootloader.
    I have a simple 116 word BLINK program that works in the PIC 18F4550 when assembled with either MPASM or PM so I am fairly confident my setup is basicly correct.
    I also have a 5k word program (attached) that works a treat with a 16F877A using the PM assembler but when I try to assemble for a 18F4550 with MPASM I get the following errors:-
    Warning [220] .......... Address exceeds maximum range for this processor.
    What is wrong - the '4550 has twice the code space of the '877A?
    Also - what box should I tick under View\Compile and Program Options. I have the choice of INHX8M, INHX8S and INHX32. INHX8S tells me I should be using INHX32. Both INHX8M and INHX32 seem to work identically with the BLINK program. What do these selections do and why should I choose one over the other?
    - all tips greatly appreciated.
  1. Moved from PM to MPASM and have fuse definition problems
    Last Post: - 26th November 2008, 23:27
  2. Problems with mpasm
    By electrosolve in forum mel PIC BASIC Pro
    Last Post: - 7th July 2008, 21:47
  3. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 02:29
  4. MPASM 18F4550 getting started
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 00:59
  5. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
