It looks like your bin_bcd routine was writen for a 16F part. RLF is not an 18F instruction.
The 18F equivalent would be RLCF.
Also FSR and INDF are different on the 18F parts. You have FSR0, FSR1, FSR2, and INDF0,
INDF1, INDF2. See the 18F data sheet for details. You'll need to make a few changes to
compile this for an 18F.
Your example compiles fine with these changes to bin_bcd;
I can't say if it works or not, but it does compile without a single error.Code:bin_bcd: asm ;****************************************************************** ; Convert 32-bit binary number at <bin> into a bcd number ; at <bcd>. Uses Mike Keitz's procedure for handling bcd ; adjust; Modified Microchip AN526 for 32-bits. b2bcd movlw 32 ; 32-bits movwf _ii ; make cycle counter clrf _bcd ; clear result area clrf _bcd+1 clrf _bcd+2 clrf _bcd+3 clrf _bcd+4 b2bcd2 movlw _bcd ; make pointer movwf fsr0 movlw 5 movwf _cnt ; Mike's routine: b2bcd3 movlw 0x33 addwf indf0,f ; add to both nybbles btfsc indf0,3 ; test if low result > 7 andlw 0xf0 ; low result >7 so take the 3 out btfsc indf0,7 ; test if high result > 7 andlw 0x0f ; high result > 7 so ok subwf indf0,f ; any results <= 7, subtract back incf fsr0,f ; point to next decfsz _cnt goto b2bcd3 rlcf _binary+3,f ; get another bit rlcf _binary+2,f rlcf _binary+1,f rlcf _binary+0,f rlcf _bcd+4,f ; put it into bcd rlcf _bcd+3,f rlcf _bcd+2,f rlcf _bcd+1,f rlcf _bcd+0,f decfsz _ii,f ; all done? goto b2bcd2 ; no, loop ; yes endasm return
