i tried checking voltage again. i get around 3mV DC across OSC1-OSC2. on the AC setting it shows nothing but im using a digital meter which might be too slow. i dug out my analog meter, but i have no clue where the leads are for it....
the OSC is a 20.0Mhz ceramic resonator with built in caps. its mountet fairly close to the PIC.
i have tried some of the different clock settings with no luck and i have switched resonators once just in case it was a bad one...
