Yup, should have, should have seen that.
Can you show the board layout's?
It's hard to follow past the via's.
ill see what i can do about the layout.. ive looked over it and it seems ok, but what do i know!!! i used eaglecads autoroute function so everything "should" be connected properly...
theres the image of the board, and i will attach the eagle file here too.
i labelled all the "important" pins. the rest go to I/Os.... and MCLR2 resistor, is a 1Mohm resistor, and its for PGM. i just didnt relabel it when i put it in there... and there was an issue with the gnd side of the caps, so i ran a jumper wire from there to the ground pin..
Probably another wrong one, but I can't tell from the picture.
Looking at some of the holes, they don't seem to be plated thru.
It could be reflections from the other side or something.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2304&stc=1&d=120158257 0" />
Where it would matter the most (if true) is on the +5V pin on that connector I should have been looking at the first time.
It doesn't have a good solder joint on the top layer, which is the side the trace connects to.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2305&stc=1&d=120158283 4" />
If the thru-hole plating is intact, it probably won't matter.
If I remember right, from the other Treadbot thread, these are homemade PCB's correct? Probably not plated thru holes unless he's got some fancy-shmancy equipment.
But that's easy enough to work around.
I'm rooting for that to be the fix..........Big bucks....no whammy's......STOP!
the treadbot board was homemade... this ones not... i can get these made at Alberta Printed Circuits for less than it costs me to make them.. and these ones have thru-plating and better traces..
