In the meantime I have another question...
I was looking for the user commands in the include and found the "DRAWLINE" ;X1,Y1,X2,Y2 , {colour} command....
What I figured by myself and what actually helps is when asking AI to write picbasic pro code, if you specify write code for "PicBasic Pro 3", not only "PicBasic Pro", it will make far less errors in...
