The loop in one line:
Claude scopes and specifies → Local LLM writes each module → Claude reviews each module → Local LLM fixes → Claude does integration review → Warp builds, flashes, and...
And in plain English, which will use more tokens , but is way easier to understand
Same example: WiFi-connected ESP32 that monitors a digital input, logs state changes with a timestamp to internal...
Because FREQOUT is using PWM with the ability to output two tones at the same time, so filtering is required to produce a, relatively clean, sinewave-looking tone.
even at 64mhz, FREQUOUT provides very low volume, distorted audio, while SOUND, even on 4Mhz 628A chip, produces loud and clear sound.
This is not chip or hardware...
Thank you Lester for the details and your efforts to explain.
Ioannis - 5th May 2026, 12:39Makes sense why to use many models.
Great tools we have now. Have to make clever use of them as you showed with detailed examples....
