The defaults setings are
- Keypad ROW are connected to PORTB<3:0>
- Keypad COL are connected to PORTB<7:4>
- Debounce delay = 200 mSec
- No auto-repeat
- Keypad type 4X4
Code example using the default setting
INCLUDE "KeyPad.bas"
myvar var byte
start:
@ READKEYPAD _myvar
hserout ["Key=",dec myvar,13,10]
goto start
If you decide to change default settings, here's the DEFINEs list
DEFINE KEYPAD_ROW 4 ' 4 ROW keypad
DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB
DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4
DEFINE KEYPAD_COL 4 ' 4 COL keypad
DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB
DEFINE KEYPAD_COL_BIT 0 ' COL0 = PORTB.0
DEFINE KEYPAD_DEBOUNCEMS 200 ' debounce delay = 200 mSec
DEFINE KEYPAD_AUTOREPEAT 1 ' use auto-repeat feature
DEFINE SCAN_ONCE 0 ; Read keypad untill a key is pressed
Code example #2: Using a 8X4 keypad
' Hardware connection
DEFINE KEYPAD_ROW 8 ' 8 row
define KEYPAD_ROW_PORT PORTB ' on PORTB
DEFINE KEYPAD_ROW_BIT 0 ' <7:0>
DEFINE KEYPAD_COL 4 ' 4 col
DEFINE KEYPAD_COL_PORT PORTA ' on PORTA
DEFINE KEYPAD_COL_BIT 0 ' <3:0>
define KEYPAD_AUTOREPEAT 1 ' use auto-repeat
' Serial Communication definition
DEFINE HSER_TXSTA 24h ' enable transmit, BRGH=1
DEFINE HSER_SPBRG 129 ' 9600 Bauds
' Variables definition
myvar var byte
' ---------------------------------[Program Start]----------------------------------------------
start:
@ READKEYPAD _myvar
goto start
Everything is explain in the attach file... don't forget to rename it
Remapping keys:
Darrel gave this answer in the thread below for re-mapping keys on the keypad. This shows reversing key order, but any key order (or dis-order) will do using the lookup function.
@ READKEYPAD _myvar ; original keys 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LOOKUP myvar,[0,16,15,14,13,12,11,10,9,8, 7, 6, 5, 4, 3, 2, 1],myvar
Sorry for late reply :)
CuriousOne Today, 06:14All I need is for it to play loud and clear.
I've added extra RC filtering circuit, as shown in manual, also I have external transistor amplifying the sound, but output is...
