The output is pretty clean in my experience. I use my photodiode in photoconductive mode (reverse bias), which makes it faster and supposedly noisier but I haven't noticed any noise except in some...
Yep, that did it! The output is now as smooth as the 16F883's output. The 16F883 used the INT_INT interrupt from the start. The GPC_INT requires the particulars you noted, and additionally it...
How clean is the output from your photodiode?
I have been working on a similar setup recently using an encoder wheel and photointerrupter.
I had greater success feeding the MCU's input...
I had thought - should I be using "INT_INT" instead of "GPC_INT"? It is set up using GPIO.2 as the interrupt pin, which is the dedicated INT pin per the datasheet. Can you set up an interrupt on...
I have a project using three 12F683s controlled by a 16F883 master. The goal of the project is to track the RPM of 4 independant propellers on a quadcopter using an IR photodiode and emitter (i.e. a...
Where can the Darrel Taylor LCD_PCF8574A.pbp i2c lcd include be found?
This is the only forum I have ever been on, I am trying to learn how to navigate around. Thank you very much for pointing out...
;cfg = _FOSC_INTOSCCLK ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN do you really need clockout on RA6...
Re: 12F683 interrupt on change improvement?
achilles03 Yesterday, 04:23
