This thread is to help us simple folk with a list of PICs, oscillator speed and configs until you know what files to use and how to read the datasheet.
This is what I'm using in my current project:
PIC 18F4550, 20 MHz external oscillator, USB operation, not using power from USB cord, using Lab-X1
PBP 2.60C
MPASM v4.02
This goes at the top of my PBP program. You can group them all in ASM/ENDASM if you prefer that method:
@ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
@ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_43_2L & _VREGEN_ON_2L
@ __CONFIG _CONFIG2H, _WDT_OFF_2H
@ __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
@ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
DEFINE OSC 48
Comment out the default configs in 18F4550.INC in PBP folder with a semi-colon like this:
ifdef PM_USED
LIST
"Error: PM does not support this device. Use MPASM."
NOLIST
LIST
LIST p = 18F4550, r = dec, w = -311, w = -230, f = inhx32
INCLUDE "P18F4550.INC" ; MPASM Header
; __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
; __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
; __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
; __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
; __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
; __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
NOLIST
LIST
These are the available options at the bottom of P18F4550 in MPASM folder:
_PLLDIV_1_1L ; No divide (4MHz input)
_PLLDIV_2_1L ; Divide by 2 (8MHz input)
_PLLDIV_3_1L ; Divide by 3 (12MHz input)
_PLLDIV_4_1L ; Divide by 4 (16MHz input)
_PLLDIV_5_1L ; Divide by 5 (20MHz input)
_PLLDIV_6_1L ; Divide by 6 (24MHz input)
_PLLDIV_10_1L ; Divide by 10 (40MHz input)
_PLLDIV_12_1L ; Divide by 12 (48MHz input)
_CPUDIV_OSC1_PLL2_1L ; [OSC1/OSC2 Src: /1][96MHz PLL Src: /2]
_CPUDIV_OSC2_PLL3_1L ; [OSC1/OSC2 Src: /2][96MHz PLL Src: /3]
_CPUDIV_OSC3_PLL4_1L ; [OSC1/OSC2 Src: /3][96MHz PLL Src: /4]
_CPUDIV_OSC4_PLL6_1L ; [OSC1/OSC2 Src: /4][96MHz PLL Src: /6]
_USBDIV_1_1L ; Clock source from OSC1/OSC2
_USBDIV_2_1L ; Clock source from 96MHz PLL/2
;----- CONFIG1H Options --------------------------------------------------
_FOSC_XT_XT_1H ; XT oscillator, XT used by USB
_FOSC_XTPLL_XT_1H ; XT oscillator, PLL enabled, XT used by USB
_FOSC_ECIO_EC_1H ; External clock, port function on RA6, EC used by USB
_FOSC_EC_EC_1H ; External clock, CLKOUT on RA6, EC used by USB
_FOSC_ECPLLIO_EC_1H ; External clock, PLL enabled, port function on RA6, EC used by USB
_FOSC_ECPLL_EC_1H ; External clock, PLL enabled, CLKOUT on RA6, EC used by USB
_FOSC_INTOSCIO_EC_1H ; Internal oscillator, port function on RA6, EC used by USB
_FOSC_INTOSC_EC_1H ; Internal oscillator, CLKOUT on RA6, EC used by USB
_FOSC_INTOSC_XT_1H ; Internal oscillator, XT used by USB
_FOSC_INTOSC_HS_1H ; Internal oscillator, HS used by USB
_FOSC_HS_1H ; HS oscillator, HS used by USB
_FOSC_HSPLL_HS_1H ; HS oscillator, PLL enabled, HS used by USB
_FCMEM_OFF_1H ; Disabled
_FCMEM_ON_1H ; Enabled
_IESO_OFF_1H ; Disabled
_IESO_ON_1H ; Enabled
;----- CONFIG2L Options --------------------------------------------------
_PWRT_ON_2L ; Enabled
_PWRT_OFF_2L ; Disabled
_BOR_OFF_2L ; Disabled
_BOR_SOFT_2L ; Controled by SBOREN
_BOR_ON_ACTIVE_2L ; Enabled when the device is not in SLEEP, SBOREN bit is disabled
_BOR_ON_2L ; Enabled, SBOREN bit is disabled
_BORV_46_2L ; 4.6V
_BORV_43_2L ; 4.3V
_BORV_28_2L ; 2.8V
_BORV_21_2L ; 2.1V
_VREGEN_OFF_2L ; Disabled
_VREGEN_ON_2L ; Enabled
;----- CONFIG2H Options --------------------------------------------------
_WDT_OFF_2H ; HW Disabled - SW Controlled
_WDT_ON_2H ; HW Enabled - SW Disabled
_WDTPS_1_2H ; 1:1
_WDTPS_2_2H ; 1:2
_WDTPS_4_2H ; 1:4
_WDTPS_8_2H ; 1:8
_WDTPS_16_2H ; 1:16
_WDTPS_32_2H ; 1:32
_WDTPS_64_2H ; 1:64
_WDTPS_128_2H ; 1:128
_WDTPS_256_2H ; 1:256
_WDTPS_512_2H ; 1:512
_WDTPS_1024_2H ; 1:1024
_WDTPS_2048_2H ; 1:2048
_WDTPS_4096_2H ; 1:4096
_WDTPS_8192_2H ; 1:8192
_WDTPS_16384_2H ; 1:16384
_WDTPS_32768_2H ; 1:32768
;----- CONFIG3H Options --------------------------------------------------
_MCLRE_OFF_3H ; Disabled
_MCLRE_ON_3H ; Enabled
_LPT1OSC_OFF_3H ; Timer1 oscillator configured for high power
_LPT1OSC_ON_3H ; Timer1 oscillator configured for low power
_PBADEN_OFF_3H ; PortB<4:0> pins are configured as digital I/O on RESET
_PBADEN_ON_3H ; PortB<4:0> pins are configured as analog input on RESET
_CCP2MX_OFF_3H ; CCP2 input/output is multiplexed with RB3
_CCP2MX_ON_3H ; CCP2 input/output is multiplexed with RC1
;----- CONFIG4L Options --------------------------------------------------
_STVREN_OFF_4L ; Disabled
_STVREN_ON_4L ; Enabled
_LVP_OFF_4L ; Disabled
_LVP_ON_4L ; Enabled
_ICPRT_OFF_4L ; Disabled
_ICPRT_ON_4L ; Enabled
_XINST_OFF_4L ; Disabled
_XINST_ON_4L ; Enabled
_DEBUG_ON_4L ; Enabled
_DEBUG_OFF_4L ; Disabled
;----- CONFIG5L Options --------------------------------------------------
_CP0_ON_5L ; Enabled
_CP0_OFF_5L ; Disabled
_CP1_ON_5L ; Enabled
_CP1_OFF_5L ; Disabled
_CP2_ON_5L ; Enabled
_CP2_OFF_5L ; Disabled
_CP3_ON_5L ; Enabled
_CP3_OFF_5L ; Disabled
;----- CONFIG5H Options --------------------------------------------------
_CPB_ON_5H ; Enabled
_CPB_OFF_5H ; Disabled
_CPD_ON_5H ; Enabled
_CPD_OFF_5H ; Disabled
;----- CONFIG6L Options --------------------------------------------------
_WRT0_ON_6L ; Enabled
_WRT0_OFF_6L ; Disabled
_WRT1_ON_6L ; Enabled
_WRT1_OFF_6L ; Disabled
_WRT2_ON_6L ; Enabled
_WRT2_OFF_6L ; Disabled
_WRT3_ON_6L ; Enabled
_WRT3_OFF_6L ; Disabled
;----- CONFIG6H Options --------------------------------------------------
_WRTB_ON_6H ; Enabled
_WRTB_OFF_6H ; Disabled
_WRTC_ON_6H ; Enabled
_WRTC_OFF_6H ; Disabled
_WRTD_ON_6H ; Enabled
_WRTD_OFF_6H ; Disabled
;----- CONFIG7L Options --------------------------------------------------
_EBTR0_ON_7L ; Enabled
_EBTR0_OFF_7L ; Disabled
_EBTR1_ON_7L ; Enabled
_EBTR1_OFF_7L ; Disabled
_EBTR2_ON_7L ; Enabled
_EBTR2_OFF_7L ; Disabled
_EBTR3_ON_7L ; Enabled
_EBTR3_OFF_7L ; Disabled
;----- CONFIG7H Options --------------------------------------------------
_EBTRB_ON_7H ; Enabled
_EBTRB_OFF_7H ; Disabled
And this is what they mean further up P18F4550.INC:
; PLLDIV = 1 No divide (4MHz input)
; PLLDIV = 2 Divide by 2 (8MHz input)
; PLLDIV = 3 Divide by 3 (12MHz input)
; PLLDIV = 4 Divide by 4 (16MHz input)
; PLLDIV = 5 Divide by 5 (20MHz input)
; PLLDIV = 6 Divide by 6 (24MHz input)
; PLLDIV = 10 Divide by 10 (40MHz input)
; PLLDIV = 12 Divide by 12 (48MHz input)
; CPU System Clock Postscaler:
; CPUDIV = OSC1_PLL2 [OSC1/OSC2 Src: /1][96MHz PLL Src: /2]
; CPUDIV = OSC2_PLL3 [OSC1/OSC2 Src: /2][96MHz PLL Src: /3]
; CPUDIV = OSC3_PLL4 [OSC1/OSC2 Src: /3][96MHz PLL Src: /4]
; CPUDIV = OSC4_PLL6 [OSC1/OSC2 Src: /4][96MHz PLL Src: /6]
; Full-Speed USB Clock Source Selection:
; USBDIV = 1 Clock source from OSC1/OSC2
; USBDIV = 2 Clock source from 96MHz PLL/2
; Oscillator Selection bits:
; FOSC = XT_XT XT oscillator, XT used by USB
; FOSC = XTPLL_XT XT oscillator, PLL enabled, XT used by USB
; FOSC = ECIO_EC External clock, port function on RA6, EC used by USB
; FOSC = EC_EC External clock, CLKOUT on RA6, EC used by USB
; FOSC = ECPLLIO_EC External clock, PLL enabled, port function on RA6, EC used by USB
; FOSC = ECPLL_EC External clock, PLL enabled, CLKOUT on RA6, EC used by USB
; FOSC = INTOSCIO_EC Internal oscillator, port function on RA6, EC used by USB
; FOSC = INTOSC_EC Internal oscillator, CLKOUT on RA6, EC used by USB
; FOSC = INTOSC_XT Internal oscillator, XT used by USB
; FOSC = INTOSC_HS Internal oscillator, HS used by USB
; FOSC = HS HS oscillator, HS used by USB
; FOSC = HSPLL_HS HS oscillator, PLL enabled, HS used by USB
; Fail Safe Clock Monitor:
; FCMEM = OFF Disabled
; FCMEM = ON Enabled
; Internal/External Switch Over:
; IESO = OFF Disabled
; IESO = ON Enabled
; Power Up Timer:
; PWRT = ON Enabled
; PWRT = OFF Disabled
; Brown Out Reset:
; BOR = OFF Disabled
; BOR = SOFT Controled by SBOREN
; BOR = ON_ACTIVE Enabled when the device is not in SLEEP, SBOREN bit is disabled
; BOR = ON Enabled, SBOREN bit is disabled
; Brown Out Voltage:
; BORV = 46 4.6V
; BORV = 43 4.3V
; BORV = 28 2.8V
; BORV = 21 2.1V
; USB Voltage Regulator Enable:
; VREGEN = OFF Disabled
; VREGEN = ON Enabled
; Watchdog Timer:
; WDT = OFF HW Disabled - SW Controlled
; WDT = ON HW Enabled - SW Disabled
; Watchdog Postscaler:
; WDTPS = 1 1:1
; WDTPS = 2 1:2
; WDTPS = 4 1:4
; WDTPS = 8 1:8
; WDTPS = 16 1:16
; WDTPS = 32 1:32
; WDTPS = 64 1:64
; WDTPS = 128 1:128
; WDTPS = 256 1:256
; WDTPS = 512 1:512
; WDTPS = 1024 1:1024
; WDTPS = 2048 1:2048
; WDTPS = 4096 1:4096
; WDTPS = 8192 1:8192
; WDTPS = 16384 1:16384
; WDTPS = 32768 1:32768
; MCLR Enable:
; MCLRE = OFF Disabled
; MCLRE = ON Enabled
; Low Power Timer1 Oscillator Enable:
; LPT1OSC = OFF Timer1 oscillator configured for high power
; LPT1OSC = ON Timer1 oscillator configured for low power
; Port B A/D Enable:
; PBADEN = OFF PortB<4:0> pins are configured as digital I/O on RESET
; PBADEN = ON PortB<4:0> pins are configured as analog input on RESET
; CCP2 Mux bit:
; CCP2MX = OFF CCP2 input/output is multiplexed with RB3
; CCP2MX = ON CCP2 input/output is multiplexed with RC1
; Stack Overflow Reset:
; STVREN = OFF Disabled
; STVREN = ON Enabled
; Low Voltage ICSP:
; LVP = OFF Disabled
; LVP = ON Enabled
; Dedicated In-Circuit Debug/Programming Enable:
; ICPRT = OFF Disabled
; ICPRT = ON Enabled
; Extended Instruction Set Enable:
; XINST = OFF Disabled
; XINST = ON Enabled
; Background Debugger Enable:
; DEBUG = ON Enabled
; DEBUG = OFF Disabled
; Code Protection Block 0:
; CP0 = ON Enabled
; CP0 = OFF Disabled
; Code Protection Block 1:
; CP1 = ON Enabled
; CP1 = OFF Disabled
; Code Protection Block 2:
; CP2 = ON Enabled
; CP2 = OFF Disabled
; Code Protection Block 3:
; CP3 = ON Enabled
; CP3 = OFF Disabled
; Boot Block Code Protection:
; CPB = ON Enabled
; CPB = OFF Disabled
; Data EEPROM Code Protection:
; CPD = ON Enabled
; CPD = OFF Disabled
; Write Protection Block 0:
; WRT0 = ON Enabled
; WRT0 = OFF Disabled
; Write Protection Block 1:
; WRT1 = ON Enabled
; WRT1 = OFF Disabled
; Write Protection Block 2:
; WRT2 = ON Enabled
; WRT2 = OFF Disabled
; Write Protection Block 3:
; WRT3 = ON Enabled
; WRT3 = OFF Disabled
; Boot Block Write Protection:
; WRTB = ON Enabled
; WRTB = OFF Disabled
; Configuration Register Write Protection:
; WRTC = ON Enabled
; WRTC = OFF Disabled
; Data EEPROM Write Protection:
; WRTD = ON Enabled
; WRTD = OFF Disabled
; Table Read Protection Block 0:
; EBTR0 = ON Enabled
; EBTR0 = OFF Disabled
; Table Read Protection Block 1:
; EBTR1 = ON Enabled
; EBTR1 = OFF Disabled
; Table Read Protection Block 2:
; EBTR2 = ON Enabled
; EBTR2 = OFF Disabled
; Table Read Protection Block 3:
; EBTR3 = ON Enabled
; EBTR3 = OFF Disabled
; Boot Block Table Read Protection:
; EBTRB = ON Enabled
; EBTRB = OFF Disabled
One thing people don't realize is that comments don't take up any space on a PIC (unless you ENABLE Insert Source File Comments in MicroCode Studio under VIEW / COMPILE AND PROGRAM). Feel free to put as many comments at the top (or bottom) of your program if it helps you remember what config does what.
I like to list them all so I don't have to go back to the datasheet/file when I want to change something.
EXAMPLE #2:
PIC Basic Pro X v3.0.8.4
MicroCode Studio Plus v5.0.0.5
MPASM v5.65
CONFIG PLLDIV = 5 ; Divide by 5 (20 MHz oscillator input)
CONFIG CPUDIV = OSC1_PLL2 ; [Primary Oscillator Src: /1][96 MHz PLL Src: /2]
CONFIG USBDIV = 2 ; USB clock source comes from the 96 MHz PLL divided by 2
CONFIG FOSC = HSPLL_HS ; HS oscillator, PLL enabled (HSPLL)
CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
CONFIG IESO = OFF ; Oscillator Switchover mode disabled
CONFIG PWRT = OFF ; PWRT disabled
CONFIG BOR = ON ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
CONFIG BORV = 3 ; Minimum setting
CONFIG VREGEN = ON ; USB voltage regulator enabled
CONFIG WDT = ON ; WDT enabled
CONFIG WDTPS = 512 ; 1:512
CONFIG CCP2MX = ON ; CCP2 input/output is multiplexed with RC1
CONFIG PBADEN = OFF ; PORTB<4:0> pins are configured as digital I/O on Reset
CONFIG LPT1OSC = OFF ; Timer1 configured for higher power operation
CONFIG MCLRE = ON ; MCLR pin enabled; RE3 input pin disabled
CONFIG STVREN = ON ; Stack full/underflow will cause Reset
CONFIG LVP = OFF ; Single-Supply ICSP disabled
CONFIG ICPRT = OFF ; ICPORT disabled
CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
CONFIG DEBUG = OFF ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
CONFIG CP0 = OFF ; Block 0 (000800-001FFFh) is not code-protected
CONFIG CP1 = OFF ; Block 1 (002000-003FFFh) is not code-protected
CONFIG CP2 = OFF ; Block 2 (004000-005FFFh) is not code-protected
CONFIG CP3 = OFF ; Block 3 (006000-007FFFh) is not code-protected
CONFIG CPB = OFF ; Boot block (000000-0007FFh) is not code-protected
CONFIG CPD = OFF ; Data EEPROM is not code-protected
CONFIG WRT0 = OFF ; Block 0 (000800-001FFFh) is not write-protected
CONFIG WRT1 = OFF ; Block 1 (002000-003FFFh) is not write-protected
CONFIG WRT2 = OFF ; Block 2 (004000-005FFFh) is not write-protected
CONFIG WRT3 = OFF ; Block 3 (006000-007FFFh) is not write-protected
CONFIG WRTC = OFF ; Configuration registers (300000-3000FFh) are not write-protected
CONFIG WRTB = OFF ; Boot block (000000-0007FFh) is not write-protected
CONFIG WRTD = OFF ; Data EEPROM is not write-protected
CONFIG EBTR0 = OFF ; Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks
CONFIG EBTR1 = OFF ; Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks
CONFIG EBTR2 = OFF ; Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks
CONFIG EBTR3 = OFF ; Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks
CONFIG EBTRB = OFF ; Boot block (000000-0007FFh) is not protected from table reads executed in other blocks
DEFINE OSC 48
Note: My first version of PBP came on a diskette and I still consider myself a beginner.
Feeding Complex Documents to Claude — How AI Reads a Datasheet and Why It Matters
lester Today, 07:51The Problem With Giving Claude a 472-Page Datasheet
The PIC16F1936 datasheet is 472 pages. It covers...
