Hello Unregistered ,
Hello, thank you for visiting the picbasic users forum. Just a little note to remind you that, if your have registeted for a user account and you have not logged in and posted a message, unused accounts are deleted from time to time.
We track user account usage. As part of our general maintenaince and to meet the GDPR requirments, we have elected to delete user accounts that are unused.
We define unused as:
NOT haveing ever posted a message on the forum
AND
NOT having logged in for more than 360 days.
If you find that your account is deleted, because of inactivity, you will need to contact the forum administrator to have the account re-instated. email: [email protected]
Thanks for the explanation. I misinterpreted these paragraphs. My understanding was to have ASYNC cleared and use Fosc/4. Ioannis
The SYNC block uses FOSC/4 as its sync clock, so it's difficult to use it if it's using FOSC/4 as its input source for counting too. 9966 for 16-bit read/write see sec 20.1.1.1: 9965 In...
Sure it is. Inside the ISR, Timer 0 is stopped, reloaded and restarted. I think is it obligatory to use Fosc/4. Unless I misunderstood the DS. Then why is it necessary to use ASYNC=1? Could...
Two things... Since you're using FOSC/4 as the source, set ASYNC bit in T0CON1. Also, when using 16 bit mode (MD16=1) you should always write TMR0H then TMR0L in that order so that the high...
looks like not reloading the tmr count every ms....... after first int, tmr counter looping from 0 .....???
Tried the files and indeed it worked OK. Sort off... I tried to setup the Timer 0 as 16bit timer, cloked by Fosc/4 with system clock at 64MHz. Reload value $C187 The toggle happens every 4...
Thanks Richard. Ioannis
sheldon sent me these for a project i was assisting with. it all seemed to work
I wonder if anyone managed to work with DT-INTS18 with the K42 series chips. The latest DT_INTS-18_K42c.bas file that tumbleweed posted (on this closed thread...
Re: K42 and Timer Interrupts
Ioannis Yesterday, 19:28I misinterpreted these paragraphs. My understanding was to have ASYNC cleared and use Fosc/4.
