Hello Unregistered ,
another issue OSCCON =% 01110010 '8MHz INTOSC OSCTUNE=% 01000000 '
Hi All, I'd like to launch the compiler/assembler and the PICKit3 programmer, all in COMMAND LINE mode, in a DOS batch file. Unfortunately, I'm getting error messages at compile/assemble time....
Random ramblings and guesses here, take for what it is: That's not how it works. The ISR triggers when there's a byte is received. You can't configure it to fire after n character (short of...
Hi Richard, thanks for the help. According to the information on the display (when set to show the 4 incoming characters), 2 initial characters are being sent as carriage return (10 and 13)...
Thanks Jerson. I corrected the links. Ioannis
yet your rx routine wants 4 chars HSERIN [RX1, RX2, RX3, rx4] what is the actual msg you receive [in ascii chrs] is there a start chr how does the msg terminate /n, /CR, /LF?
Hi guys, I'm facing a weird behaviour with my 18F2580 using Hserin and RX interrupts and I was hoping someone could help. I'm trying to run a code that when an incoming 2 characters is...
Hi Ioannis Your links are broken due to the ellipsis within them. I have just one link here by searching for wilkol and high resolution frequency counter ...
Long time ago, Microchip had that AN592 to show how a PIC16C54 can measure up to 50MHz frequencies, which was indeed very impressive. About 6 years ago this Instructable by user WilkoL did a High...
maybe like this https://youtu.be/PQrvgA-w0gk steps through an array to set portb pin and another array to set timer interval for next interrupt , repeats every 6th pass ra0 toggles every...
Re: 18F2580 with strange behaviour when using Hserin and RX interrupt
another issue
richard Yesterday, 22:52OSCCON =% 01110010 '8MHz INTOSC OSCTUNE=% 01000000 '
