MenuAre you repeating the same code 30 times since the messages differ? Then, possibly, you could be facing this issue as strings gobble up memory pretty fast.
I would look at the feasibility of...
simple ws0010 oled graphics driver for my graphical display library
https://youtu.be/TVMprQoQLqQ
I'm using this for such cases:
topline: 'top line updater sub
ofs=pos*16 'modify position offset
for x=0 to 15
i2cread sda, scl, adr, x+ofs, [y] 'write from eeprom
tline[x]=y 'write into...
Hi all,
I have a application with the 16F882 and have add some data. But the memory is run over.
The '882 = 2048 words, "883 is only 4096 words.
I drive a LCD (1602) RS485 and some LEDs and...
I would be too worried about it, afaics it's totally undocumented for pbp and if you don't do much asm work you may rarely come across its usage
richard - 18th March 2026, 09:29
Sorry for my dumb question!
I'm mixing things up between PBP and another programming language where the semicolon supresses the CR/LF (Liberty Basic).
Sorry... :o
comments begin with an apostrophe or a semicolon, so its a blank comment
richard - 15th March 2026, 23:52
Re: memory full
Yeah, lots of repeating code there...
HenrikOlsson Yesterday, 07:21For starters, move the LCDOUT commands to a subroutine.
Unless you're running HSEROUT at 150baud or something you can most likely remove the PAUSE 5 after...
