Most of the commonly-used methods (like HSERIN [DEC numdata] work, but provide no user feedback as to what they are typing. It also doesn't allow for backspacing. This include file provides both.
As an added bonus, the file lets you input negative numbers by typing a "-" before the number. And, because people who are used to occasionally putting a "-" before their entry may also put a "+", the file will accept this also.
This routine will work with most serial terminal programs, like HYPERTERM and Bray's TERMINAL. No fancy emulation modes (VT-XX) need to be selected.
The INCLUDE has several defaults that can be overridden by changing the values of certain variables before the INCLUDE is called via a GOSUB. These defaults include the maximum number of characters (MAXCHAR), whether or not "-" and "+" will be allowed before the number entry (ALLLOWSIGN), and the timeout - how long the routine will wait with no input before returning.
If the MAXCHAR limit is reached, the value is returned as if an <ENTER> had been pressed. Of course, an <ENTER> can be pressed at any time. 5 is the default.
If ALLOWSIGN = 1, then a "+" or "-" will be allowed - BUT ONLY IN THE LEFTMOST POSITION. A "+" is displayed, but "thrown away" later. A "-" on the other hand, will return the twos compliment of the number.
Pressing <ESC> will return the value of zero and set bit 2 of the variable KERROR. Likewise, entering nothing will cause a timeout and will set KERROR bit 1 and return a value of zero. Entering a negative number that is too large will set KERROR bit 0.
Kerror bit 7 will be set if the returned value is negative.
The returned value is KRETURNED.
To invoke the utility :
This routine is written for hardware serial ports. Although software ports (SERIN2) CAN be used, I discourage this horrible practice whenever I can.
USAGE:
<Set up serial port>
INCLUDE "KBNumberInput.bas"
<Change defaults, if desired>
Hserout [CR,LF,"Give me the number "]
Gosub GetNum
IF !Kerror then
HSEROUT [CR,LF,"The number you typed in was ",#KResult]
if Kerror.7 then
HSEROUT [CR,LF,"The NEGATIVE number you typed in was ",SDEC Keyresult]
<Process errors here>
;----------------------------------------------------------------------------------------- ; Numeric Input Routine by Charles Linquist ; Set MaxNum to maximum number of digits you will take (default = 5) ; Set KInputTimeout to the number of secs you will wait before giving up. ; If you will accept a sign ("+" or "-") then set AllowSign to 1 in your ; program it will over-ride these values ; ; KRESULT is , well, the result. ;----------------------------------------------------------------------------------------- Keyin var byte Maxnum var byte YY var word POSN var byte AllowSign var bit Kerror var Byte KInputString var byte [10] KResult Var word KInputTimeout var Word XN var byte BS CON 8 ESC cON 27 LF con 10 SP con 32 CR con 13 MaxNum = 5 ; max number of chars KInputTimeout = 10000 ; 10 sec AllowSign = 0 goto OverKInput GetNum: KResult = 0 Kerror = 0 YY = 1 POSN=0 ArrayWrite KInputString,[Rep $FF\8] ; Fill with $FF GetMoreN: HSERIN KInputTimeout,DeadAtKeyboard,[Keyin] IF Keyin = ESC THEN Escaped If Keyin = CR THEN DunInputn If AllowSign then IF Posn = 0 THEN If Keyin = "-" THEN Kerror.7 = 1 Hserout ["-"] goto GetMoreN endif if Keyin = "+" then Hserout ["+"] goto GetMoreN endif ENDIF endif IF Keyin = BS THEN IF POSN > 0 THEN HSEROUT [BS,SP,BS] POSN = POSN - 1 KInputString [POSN] = $FF GOTO GetMoreN ENDIF ENDIF iF POSN >= MaxNum THEN goto DunInputN IF Keyin < "0" or Keyin > "9" THEN GetMoreN HSEROUT [Keyin] KInputString [POSN] = Keyin - "0" POSN = POSN +1 GOTO GetMoreN DunInputN: For xN = 4 to 0 STEP - 1 IF KInputString[XN]= 255 THEN NotANum KResult = KResult + (KInputString[xN]*YY) YY = YY *10 NotANum: Next XN If Kerror.7 then If Kresult < 32768 then KResult = 0 - KResult else Kerror.0 = 1 goto zeronum endif endif Return ; success DeadAtKeyboard: Kerror.1 = 1 Goto ZeroNum Escaped: Kerror.2 = 1 ZeroNum: KResult = 0 RETURN OverKInput:
No attempt has been made to prevent entries over 65535. An easy way to prevent this mistake is to set MAXNUM to 4. This will make it impossible to enter numbers over 9999.
Re: K42 and Timer Interrupts
Thanks for the explanation.
Ioannis - 28th April 2025, 19:28I misinterpreted these paragraphs. My understanding was to have ASYNC cleared and use Fosc/4.
