Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    SWITZERLAND (french speaking)
    Default PULSIN resolution
    Quote Originally Posted by gmglickman View Post
     if (pulse < 220) or (pulse > 260) then start
    might be a little tight to capture the 240msec AGC pulse at the start. See below.
    @ 4MHz, PULSIN has 10µs resolution.
    If you need to capture 240msec, then you would have:
     if (pulse < 22) or (pulse > 26) then start
    I did something similar and left PULSIN by side - I use TMR1 instead. Have a look to the "code" section here http://home.citycable.ch/flotulopex/...I_Frames_e.htm
    HTH
    Roger
    Feb 2010
    Albuquerque
    Default Timing
    I dont think the timing is off becuase I used a portion of the first code to make shure the range of numbers was correct.
    start:
    high GPIO.2
    low GPIO.2
    goto start
    I think this was the code but I used 220 through 260 and the led would flash every time it detected the ACG pulse. So I dont think the values are incorrect. I just dont know how to excecute the program.
    I would really like to use this code below because I understand it, it's simple and I can do it all in software. If anyone can please tell me what is wrong with this code please let me know.
    pulse  var Word
    x      var byte
    signal var word
    ANSEL = %00000000
    Start:
        Pulsin PORTC.3, 0, pulse
    signal = 0
    x = 1
    Loop:
        pulsin PORTC.3, 0, pulse
        if (pulse > 90) then ADD_X
        READ_IR:
        x = x * 2
        if (x = 255) then start
        serout PORTC.2, 2, [#signal]
        goto loop
    ADD_X:
        signal = signal + x
        goto read_ir
    One Sony decoder chip comin up..
    This should be easy to understand & modify for your PIC type. And you can easily change it to display buttons like channel-up, down, volume-up, down, etc..
    IR_PULSE VAR BYTE(12) ' IR data received
    INDEX VAR BYTE        ' Index pointer
    DBYTE VAR BYTE        ' IR data received
       PULSIN PORTC.3,0,IR_PULSE         '// Read-in start pulse
       IF (IR_PULSE < 200) OR (IR_PULSE = 0) THEN Main
    Verify:                              '// Read, Decode, then verify data
       FOR Index = 0 TO 11               '// Setup to read-in 12 pulses
        PULSIN PORTC.3,0,IR_PULSE[Index] '// Read 12 low-going pulses on RC.3
       NEXT Index                        '// Loop x times
       DBYTE = $7F                       '// Start with all 1's and find each 0
       FOR Index = 0 TO 6                '// Get 7 "data" bits
        IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
       NEXT Index
       DBYTE = DBYTE + 1                 '// Button code #1 = 0, Button #2 = 1, so add 1
                                         '// for actual button pressed for display
       HSEROUT ["Button pressed was ",#DBYTE,13,10]
       GOTO Main
    This will print buttons #1 through #9. Buttons 0, channel, volume, etc will output the numeric values corresponding to buttons pressed.
    I know you don't care about the device codes like TV, VCR, etc, but it's easier to keep in-synch if you read these in anyway.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2008
    Ploiesti, ROMANIA
    Wow, Mr.Bruce, amazing job !!! I wonder if it's possible to create code (like this) for using with RC-10 infrared remote from Blaupunkt. I read something about remote with buttons here : http://dren.dk/lacetti-blaupunkt.html, but it' s more interesting to build one infrared remote. In the car that will make the difference ... I read all topics on this forum about IR, and Yours web pages too, but my level of knowledges it's (verry) low...so, if it's possible, every help it's wellcome.
