Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    Dec 2008
    Ploiesti, ROMANIA
    Default Heeeeeelp, please ...:(....
    I try different variant of PBP code; no result.
    I find the example of Mr.Bruce :
      ' IR carrier generator routines. Freq.inc.
      Cycles VAR BYTE    ' Number of carrier cycles
      GOTO OverFreq  ' jump over pulse routines
    ' Generate "Cycles" number of 40kHz pulses
    _Pulse40
       bcf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bsf IRTX,PIN     ; 1uS, LED=on
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse40    ; + 2uS = 12uS
       return           ; Return to caller
    ' Generate "Cycles" number of ~38.4kHz pulses
    _Pulse38
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
    OverFreq:
    so I write my program, for the hardware like in schematic ( for now I test just Volume Up) :
    @ DEVICE PIC12F675, intrc_osc, wdt_off, pwrt_off, mclr_off, bod_off
    DEFINE OSC  4
    DEFINE OSCCAL_1K 1          ' Set OSCCAL for 1k -HELPS tuning the crystal for more accurate timing
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 1      ; Define port pin to use for IR out
    INCLUDE "Freq.inc" '
    but  var gpio.5
    GPIO.5=1
    TRISIO.5=1
    GPIO.1 = 1       ' IR LED off   -----|<|----/\/\/\----+5
    TRISIO.1 = 0     ' Output for IR signal
    WPU     = %00111101
      CMCON = 7        ' Comparators disabled
      ANSEL = 0        ' A/D disabled
    Loops VAR BYTE
    if but=0 then
            FOR Loops = 1 TO 10
              Cycles = 102      ' 102 * 26 = 2652 uS
              CALL Pulse38
              Pauseus 2580      ' accurate pause of 2580 uS ?!?
              Cycles = 25       ' 25 * 26 = 650 uS ; maybe must EXACTLY 660 uS - how ?!?
              CALL Pulse38
              pauseus 50000
              pauseus 50000
             Next loops
    GOTO Main
    but, OF COURSE ?!?, no results. Somebody, just one little help ? Please...
    Are you sure your IR LED lights? I mean of course you cannot see it. But with camera or your mobil phone maybe you can see if the LED is lighting.
    Do not trust this very much, since my SONY DSC-W17 does not see any IR at all! So test this first with a known IR transmitter to be sure.
    Dec 2008
    Ploiesti, ROMANIA
    I test the function of my schematic with two phones camera (Nokia & S-E) ; and with InfraX soft too. I capture the signal with TSOP 1738 on serial port, for "original" remote and for "PIC" remote...Works fine...but without results on my RC ! Thanks for support !
    I see a 55us diffrence in the two shots. May be this is the problem.
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes, I know...
    ...and I say in previous post :
              CALL Pulse38
    Suggestions ? Thank You for attention !
    You may very well declare a 1234usec delay but this depends on the accuracy of the System Clock (Crystal resonator or what ever).
    So you may have to trim a little the value of the pauseus to get exactly the time you want.
    In general IR systems I eel are able to tolerate such skews...
    Dec 2008
    Ploiesti, ROMANIA
    Default YES ! Finally I have results !
    After thousands of re-writing this code, I've got finally results :
    @ DEVICE PIC12F675, INTRC_OSC_NOCLKOUT, wdt_off, pwrt_off, mclr_off, bod_off
    @ #define PIN 1         ; Define port pin for IR out
     Puls_a         CON 112  ' 112 x 26uS = 2912 mS ( pulse with carrier ON)
    InterPulse  CON 2800 ' 2.80mS (delay between pulses with carrier OFF)
    Puls_b        CON 28   ' 28 x 26uS = 728 uS   ( pulse with carrier ON)
    X        VAR BYTE ' Data bit loop counter & bit index pointer
    Duration VAR BYTE ' Duration of button press
    Loops    VAR BYTE ' Loop count
    Cycles   VAR BYTE BANK0 SYSTEM' Number of carrier cycles to generate
    trisio=%11111101
    option_reg.7=0
    wpu	=%11111101
    but  var gpio.5
        GOTO Main       ' Jump over pulse routine to Main
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
    ASM                 ; Keep this routine in code page 1, and jump over to Main
       	BSF	IRTX,PIN		      ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	BCF	IRTX,PIN		      ; 1 MAKE IR LOW 17 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	DECFSZ	Cycles,F
    	GOTO	_Pulse	      ; 2    26 uS
       return           ' Return to caller
    Duration = 2    ' Send it twice
    IF BUT=0 THEN
    For Duration = 1 to 2
            Cycles = Synch         ' carrier on
            Call Puls_a             ' Send pulse
            PAUSEUS InterPulse    ' Pause (carrier off)
            Cycles = Logic0        ' carrier on
            Call Puls_b             ' Send pulse
    		Pauseus 50000
    		Pauseus 50000
    Next Duration
        GOTO Main                  ' Return for more
    This is command for Volume Up only ; instead 102 cycles * 26 uS = 2650 uS, I put 112 * 26 = 2912, etc. So, the lenght of one pulse is 23.5 uS ?! Maybe with this PIC... Anyway, it's good to see that working, after hard work... Thank You all for support; every advice it's further wellcome !
