Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    Oct 2007
    The Netherlands
    You should modulate your signal on a carrier of about 38 kHz. You can generate this with assembly or use a pic12f683 and use the internal pwm generator. Then you can modulate this signal by switching the trisio pin.
    I once did it this way:
    It sends a Sony DVD play command every five seconds (as an example)
    @ device  pic12F683, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, protect_off, bod_off
    INCLUDE "MODEDEFS.BAS"
    DEFINE PULSIN_MAX 5000
    GPIO      =       %00100000
    TRISIO    =       %00001100
    CCP1CON   =       %00001100  ' Mode select = PWM
    T2CON     =       %00000100  ' Timer2 ON + 1:1 prescale (last two bits)
    CCPR1L	  =       %00001101  ' pwm duty 50%
    PR2       =       %00011001  ' Set PWM frequency to +/- 40kHz, set to 26 for 38kHz or 28 for 36kHz
    ANSEL     =       %00000000
    CMCON0    =       %00000111
    led       var     GPIO.5
    counter   VAR     BYTE
    counter2  VAR     BYTE
    command   VAR     WORD		                            'IR command to send
    temp      VAR     WORD
    bitcount  VAR     WORD
    bitselector var   word
    rewind    CON     $79A	                                'sony DVD codes for testing
    play      CON     $59A
    postdata  con     $36
    clear
    loop:
       command =  play
       gosub sendIR
       pause 5000
    goto loop
    sendIR:								' send IR code
        for counter = 1 to 5            ' five times
            TRISIO.2 = 0
            PauseUs 2450	            ' Lead_in pulse
        	TRISIO.2 = 1
        	pauseus 450                 ' (space)
            bitcount = 11               ' send first 11 bits
            temp = command
            GoSub transmit
            bitcount = 8                ' send remaining 8 bits
            temp = postdata
            GoSub transmit
            TRISIO.2 = 0
            PauseUs 650	                ' ptrail (pulse)
            TRISIO.2 = 1
            Pauseus 13080
        next counter
    transmit:
    	bitselector = 1 << (bitcount - 1)
            For counter2 = 1 TO bitcount	        'number of bits
    		TRISIO.2 = 0				'make output (pin active, led on)
    		PauseUs 540			        'first part of bit, pulse
                    IF (temp & bitselector) = 0 Then 'if bit is 0
    			PauseUs 580			'send second part of bit ,pulse
    		EndIF
    		TRISIO.2 = 1				'make input (pin inactive, led off)
    		PauseUs 560                              'space (no pulse)
                    temp = temp << 1			'shift one bit
    	Next counter2
    Feb 2010
    Albuquerque
    Smile Got it working
    I finally got the code working but it is very ineffecient. I am only 17 and I came up with the code with only a little help so give me some credit. Its not the best but if any of you have other ways to compress the code and make it more effecient please reply. Thanks
    ANSEL = %00000000
    IR_PULSE    var word(11)
    SIGNAL      var word
    START_PULSE var word
    INDEX       var byte
    X           var byte
        Pulsin PORTC.3, 0, start_pulse
        if (start_pulse < 220) or (start_pulse > 260) then main
        for index = 0 to 11
            pulsin PORTC.3, 0, ir_pulse(index)
        next index
    Convert:
    x = 1
    signal = 0
        for index = 0 to 11
            if (ir_pulse(index) > 90) then ADD_X
            READ_IR:
            x = x * 2
        next index
        serout PORTC.2, 2, [#signal, 9]
        clear
    ADD_X:
        signal = signal + x
        goto read_ir
    Dec 2008
    Ploiesti, ROMANIA
    Quote Originally Posted by eggman View Post
    I intend to build remote using 12F675 (I have a lot...and none of 12F683). How generating a carrier of 39 kHz with assembly ? I found something about 40 kHz pulse on Mr.Bruce site, but...
    Please, one clue ?!
    Pulse: '// Emits # of 39kHz bursts held in variable Cycles
    ASM ;// with auto delay between bursts
    bsf gpio, 0 ;// 1uS, LED=on [need 25uS total ???????
    goto $+1 ;// 3uS (2uS per goto $+1)
    goto $+1 ;// 5uS
    goto $+1 ;// 7uS
    goto $+1 ;// 9uS
    goto $+1 ;// 11uS
    ' goto $+1 ;// 13uS 'comment this for 39 kHz ???
    bcf gpio, 0 ;// 14uS, LED=off
    goto $+1 ;// 16uS
    goto $+1 ;// 18uS
    goto $+1 ;// 20uS
    goto $+1 ;// 22uS
    decfsz _Cycles,F ;// 23uS
    goto _Pulse ;// 25us
    PAUSEUS 500 '// 500uS delay between each data bit
    RETURN '// Return to Main
    ...and next ?
    Dec 2008
    Ploiesti, ROMANIA
    Unhappy ?!?
    I try to simulate this remote using 12F683 (because of PWM) :
    GPIO      =       %00000010
    TRISIO    =       %00000010
    ANSEL     =       %00000000
    CMCON0    =       %00000111
    led   var GPIO.5
    but1 	var GPIO.1
    LED=0
    delay		var word
    i 		var byte
    timeX       var byte
    if but1=0 then  vol_up
    vol_up:
        delay = 970 '(970 us low + 970 us high + 660 us low = 2600 us pulse total time)
    	while but1=0
    		gosub ir_out
    		gosub debounce
    	wend
    PAUSE 50
    Goto Main
    ir_out:
            led=1
            pauseus delay
            led=0
            pauseus delay
            led=1
            pauseus 660
            led=0
            pause 10    'wait 10ms before repeating
    Debounce :
    For timeX= 1 to 50
    Pause 5
    next timeX
    END         ' of program
    But the results are similarly ; I really don't understand what I do wrong ...
    Oct 2007
    The Netherlands
    Instead of led = 1 or led = 0 use this: TRISIO.2 = 0 or TRISIO.2 = 1
    You have to connect your IR led to GPIO.2, not GPIO.5
    Toggling TRISIO.2 will modulate your IR led
