Hope don't disturb if I continue here with "code" for RC10 remote...If necessary please move in separate topic. Thanks.
It's my (pseudo)code...Any advice it's wellcome !
' First variant for RC 10 Blaupunkt remote
;           PIC12F675:                    +--U--+
;                                    +5V  [     ]  GND
;                         key 5 |---/--- >[     ]< ---/---| key 1
;                         key 4 |---/--- >[     ]< ---/---| key 2
;       pull-up!          key 3 |---/--- >[     ]>--[4K7]-- NPN Transistor, IR LED
@ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off
DEFINE OSC  4
CMCON=7
OPTION_REG  = %00000111
TRISIO  = %00111110
WPU=%00110111
ANSEL=0
but1 var gpio.1
but2 var gpio.2
but3 var gpio.3
but4 var gpio.4
but5 var gpio.5
LED  var gpio.0
GIE  var intcon.7 ' global interrupt enable 1=on ; 0=off
gpie var intcon.3 'port change interrupt enable 1=0n ; 0=off
gpif var intcon.0 'port change interrupt flag bit
GIE=0
GPIE=1
IOC.1=1   ' int-on-change for GPIO.1 enabled
IOC.2=1   ' int-on-change for GPIO.2 enabled
IOC.3=1   ' int-on-change for GPIO.3 enabled
IOC.4=1   ' int-on-change for GPIO.4 enabled
IOC.5=1   ' int-on-change for GPIO.5 enabled
LED=1
delay var word
i var byte
 @ sleep
if but1=1 then  vol_up
if but2=1 then  vol_down
if but3=1 then  btn_up
if but4=1 then  btn_down
if but5=1 then  mute
vol_up:
    delay = 2600
    gosub ir_out
vol_down:
    delay = 3200
    gosub ir_out
btn_up:
    delay = 3800
    gosub ir_out
btn_down:
    delay = 4400
    gosub ir_out
mute:
    delay = 5000
    gosub ir_out
GPIF=0  'Clear port change interrupt flag
Goto Main
ir_out:
    for i = 1 to 10 'sends out command 10 times
        led=0
        pauseus delay
        led=1
        pauseus delay
        led=0
        pauseus 660
        led=1
        pause 10    'wait 10ms before repeating
    next i
END         ' of program
