Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    Even better if you can afford the Logic from www.saleae.com to analyse digital signals. It saved me many times when trying to copy signals from similar cases.
    Dec 2008
    Ploiesti, ROMANIA
    Default Instead to party for my Birthday....
    I spend time with this "killer" code. Now I discover another strange phenomenon : anything I do, can't generate "train" of pulse.
    Instead generating for 4 times this sequence : high 2650 ,pause 2500, high 660, pause 100
    I have just ONE sequence for about 42.25 mS !!!
    WHY ?!?
    zecime  CON 106    '// = ( 106 * 25uS) = 2650 uS burst
    unu       CON 24     '// = (24 * 25uS) = 0.60 mS burst
    delay     CON 104
    i 		var byte
    cycles	var byte
    acycles      var byte
    IF but1=0 then 			; VOLUME UP
        goto ir_send
    Goto Main
    ir_send:
         	cycles=zecime
            acycles=unu
     for i=1 to 4
            call Pulse
            pauseus  delay
            call Pulser
     next i
    Pauseus 100
    Goto main        ' or Return, have no result !
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
       bsf gpio, 2     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bcf gpio, 2     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse      ; + 2uS = 12uS
       return           ; Add 2uS for return to caller
    Pulser:              ' Generate "Cycles" number of 40kHz pulses
       decfsz _Acycles,f ; + 1uS = 10S
       goto _Pulser      ; + 2uS = 12uS
    Thanks again for attention !
    Dec 2008
    Ploiesti, ROMANIA
    On first row: original Blaupunkt remote, volume up command.
    On second row : my remote, volume up command.
    Using same sensor (original Blaupunkt).
    Original-work; my-NO !!! I'm stuck, dissapointed, sad...
    Could you attach the 2 wav/mp3 files? I'll open them in a sound editor at my end; couldnt quite see the whole pulse train.
    If this forum doesnt permit audio attachments, you could mail them to me at ardhuru_at_gmail.com.
    Also, some remotes send the same frame twice; does your Blaupunkt need that?
    Anand.
    Dec 2008
    Ploiesti, ROMANIA
    Default Heeeeeelp, please ...:(....
    I try different variant of PBP code; no result.
    I find the example of Mr.Bruce :
      ' IR carrier generator routines. Freq.inc.
      Cycles VAR BYTE    ' Number of carrier cycles
      GOTO OverFreq  ' jump over pulse routines
    _Pulse40
       bcf IRTX,PIN     ; 1uS, LED=on
       bsf IRTX,PIN     ; 1uS, LED=on
       goto _Pulse40    ; + 2uS = 12uS
       return           ; Return to caller
    ' Generate "Cycles" number of ~38.4kHz pulses
    _Pulse38
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
    OverFreq:
    so I write my program, for the hardware like in schematic ( for now I test just Volume Up) :
    @ DEVICE PIC12F675, intrc_osc, wdt_off, pwrt_off, mclr_off, bod_off
    DEFINE OSC  4
    DEFINE OSCCAL_1K 1          ' Set OSCCAL for 1k -HELPS tuning the crystal for more accurate timing
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 1      ; Define port pin to use for IR out
    INCLUDE "Freq.inc" '
    but  var gpio.5
    GPIO.5=1
    TRISIO.5=1
    GPIO.1 = 1       ' IR LED off   -----|<|----/\/\/\----+5
    TRISIO.1 = 0     ' Output for IR signal
    WPU     = %00111101
      CMCON = 7        ' Comparators disabled
      ANSEL = 0        ' A/D disabled
    Loops VAR BYTE
    if but=0 then
            FOR Loops = 1 TO 10
              Cycles = 102      ' 102 * 26 = 2652 uS
              CALL Pulse38
              Pauseus 2580      ' accurate pause of 2580 uS ?!?
              Cycles = 25       ' 25 * 26 = 650 uS ; maybe must EXACTLY 660 uS - how ?!?
              CALL Pulse38
              pauseus 50000
              pauseus 50000
             Next loops
    GOTO Main
    but, OF COURSE ?!?, no results. Somebody, just one little help ? Please...
    Are you sure your IR LED lights? I mean of course you cannot see it. But with camera or your mobil phone maybe you can see if the LED is lighting.
    Do not trust this very much, since my SONY DSC-W17 does not see any IR at all! So test this first with a known IR transmitter to be sure.
    Dec 2008
    Ploiesti, ROMANIA
    I test the function of my schematic with two phones camera (Nokia & S-E) ; and with InfraX soft too. I capture the signal with TSOP 1738 on serial port, for "original" remote and for "PIC" remote...Works fine...but without results on my RC ! Thanks for support !
