Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    Dec 2008
    Ploiesti, ROMANIA
    Ok, Thanks ! With 16F648A works (in ISIS ) great.
    But...
    I find in "Experimenting with the PicBasic Pro Compiler" by Les Johnson how to define subroutine "Pulse" ; so, I re-re-x-rewrite code for 12F675. I have some results but I don't understand how define the lenght of pulses. I put "?!" where I don't know if it's right.
    Any advices ?
    '           PIC12F675:                    +--U--+
    '                                    +5V  [     ]  GND
    '                         key 5 |---/--- >[     ]< ---/---| key 1
    '                         key 4 |---/--- >[     ]< ---/---| key 2
    '       pull-up!          key 3 |---/--- >[     ]>--[4K7]-- NPN Transistor, IR LED
    @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off
    INCLUDE "MODEDEFS.BAS"
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    but1 var gpio.0
    but2 var gpio.1
    LED  var gpio.2
    but3 var gpio.3
    but4 var gpio.4
    but5 var gpio.5
    delay		var word
    BURST		var word
    i 		var byte
    timeX       var byte
    GIE  var intcon.7 ' global interrupt enable 1=on ; 0=off
    gpie var intcon.3 ' port change interrupt enable 1=0n ; 0=off
    gpif var intcon.0 ' port change interrupt flag bit
    GIE=0
    GPIE=1
     @ sleep
    IF but1=0 then 			; VOLUME UP
        DELAY=37                  ; 970 us/ 26 us each pulse = 37 ?!
        	GOSUB IR_REMOTE
    IF but2=0 then 			; VOLUME DOWN
        DELAY=1270
    	GOSUB IR_REMOTE
    IF but3=0 then 			; BUTTON UP
        DELAY=1570
    	GOSUB IR_REMOTE
    IF but4=0 then 			; BUTTON DOWN
        DELAY=1870
    	GOSUB IR_REMOTE
    IF but5=0 then 			; MUTE
        DELAY=2170
    	GOSUB IR_REMOTE
    GPIF=0  'Clear port change interrupt flag
    PAUSE 50
    Goto Main
    ir_REMOTE:
    FOR BURST=1 TO DELAY
    GOSUB PULSE
    NEXT BURST
    pauseus (delay*26)         '    ?!
    FOR BURST=1 TO 25          ' 660/26 ?!
    GOSUB PULSE
    NEXT BURST
    Pulse:            ' 2+4+8+4+7+1=26 us
    HIGH LED		' Turn on LED (4 cycles)
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP			' each NOP takes 1 instruction cycle
    @ NOP			' assumig 4 MHz
    @ NOP
    @ NOP
    LOW LED           ' turn off the LED (4 cycles)
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    RETURN            ' return from the subroutine (1 cycle)
    END         ' of program
    Dec 2008
    Ploiesti, ROMANIA
    This is my last variant of code; works fine in ISIS, hope to my car too.
    '       Varianta cu ASM from www.rentron.com
    '              Thanks to Mr.Bruce !
    '                                    +5V  [     ]  GND
    @ DEVICE PIC12F675, intrc_osc, wdt_off, pwrt_on, mclr_off, bod_off
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    but1 var gpio.0
    but2 var gpio.1
    LED  var gpio.2
    but3 var gpio.3
    but4 var gpio.4
    but5 var gpio.5
    zecime   CON  3      '// = ( 3 * 25uS) = 0.07 mS burst
    zero     CON 12      '// =( 12 * 25us) = 0.30 mS burst
    unu      CON 24      '// = (24 * 25uS) = 0.60 mS burst
    delay		var word
    i 		var byte
    cycles	var byte
    acycles     var byte
    GIE=0
    GPIE=1
     @ sleep
    acycles= unu + zero + zecime  		' ~ 970 uS
          delay=970
        	GOSUB IR_REMOTE
    acycles= unu + unu + zecime   		' ~ 1270 uS
    	delay= 1270
    	GOSUB IR_REMOTE
    acycles= unu + unu + zero + zecime 		' ~ 1570 uS
          delay = 1570
    	GOSUB IR_REMOTE
    acycles= unu + unu + unu + zecime  		' ~ 1870 uS
          delay = 1870
    	GOSUB IR_REMOTE
    acycles= unu + unu + unu + zero + zecime 	' ~ 2170 uS
          delay = 2170
    	GOSUB IR_REMOTE
    PAUSE 50
    Goto Main
    ir_REMOTE:
    cycles=acycles
    call Pulse
    pauseus  delay
    cycles=zero + zecime     			' ~ 670 uS
    call Pulse
    Pulse:                '// Emits # of 40kHz bursts held in variable Cycles
    ASM                   ;// with auto delay between bursts
       bsf gpio, 2        ;// 1uS, LED=on [need 25uS total
       goto $+1           ;// 3uS (2uS per goto $+1)
       goto $+1           ;// 5uS
       goto $+1           ;// 7uS
       goto $+1           ;// 9uS
       goto $+1           ;// 11uS
       goto $+1           ;// 13uS
       bcf gpio, 2        ;// 14uS, LED=off
       goto $+1           ;// 16uS
       goto $+1           ;// 18uS
       goto $+1           ;// 20uS
       goto $+1           ;// 22uS
       decfsz _Cycles,F   ;// 23uS
       goto _Pulse        ;// 25us
    RETURN                '// Return to Main
    If see obviously mistakes, please tell me. Thank You, all !
    Dec 2008
    Ploiesti, ROMANIA
    Default ...please help !
    " I have not failed. I've just found 10,000 ways that won't work". T.A.Edison
    Code :
    '                                    +5V  [     ]  GND
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    GPIO = %00000000        ' All outputs = 0 on boot
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    @ #DEFINE IRTX GPIO  ; Define port to use for IR LED drive
    @ #DEFINE PIN 2      ; Define port pin to use for IR LED
    but1 var gpio.0
    but2 var gpio.1
    but5 var gpio.5
    vplus   	CON  106      '// = ( 106 * 25uS) = 2650 uS burst
    vminus     	CON  130      '// = ( 130 * 25us) = 3250 uS burst
    vmute      	CON  202      '// = ( 202 * 25uS) = 5050 uS burst
    vpuls       CON   27      '// = (  27 * 25uS) =  675 uS burst
    delay		var word
    cycles	var byte
    acycles     var byte
    timeX       var byte
    GIE=0
    GPIE=1
     @ sleep
    acycles = vplus
          delay = 2580
    while but1=0
        	GOSUB IR_REMOTE
    wend
    acycles = vminus
    	delay = 3200
    while but2=0
        	GOSUB IR_REMOTE
    wend
    acycles = vmute
          delay = 5000
    while but5=0
        	GOSUB IR_REMOTE
    wend
    PAUSE 50
    Goto Main
    ir_REMOTE:
    cycles=acycles
    call Pulse
    pauseus  delay
    cycles=vpuls     			' ~ 670 uS
    call Pulse
    PAUSE 500
    Pulse:                '// Emits # of 39kHz bursts held in variable Cycles
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse      ; + 2uS = 12uS
    Debounce :
    For timeX= 1 to 50
    Pause 5
    next timeX
    Of course, zero result ! Even ISIS say it's ok, my RC Blaupuntk don't react ! I have one original RC 10 remote (and receiver, of course) from one friend; works fine. But, if I try to transmit something with my schematic...zero result ! Any advice, please ?!?
    At this point, it might be a good idea to actually, visually compare the original signal with the one generated by your design. Capture the signals on your PC using the sound card, and open the captured file(s) with Goldwave / Audacity.
    You'd immediately see whether the problem is to do with timing / protocol / logic or amplitude.
    Anand
    Even better if you can afford the Logic from www.saleae.com to analyse digital signals. It saved me many times when trying to copy signals from similar cases.
    Dec 2008
    Ploiesti, ROMANIA
    Default Instead to party for my Birthday....
    I spend time with this "killer" code. Now I discover another strange phenomenon : anything I do, can't generate "train" of pulse.
    Instead generating for 4 times this sequence : high 2650 ,pause 2500, high 660, pause 100
    I have just ONE sequence for about 42.25 mS !!!
    WHY ?!?
    zecime  CON 106    '// = ( 106 * 25uS) = 2650 uS burst
    delay     CON 104
    i 		var byte
    cycles	var byte
    acycles      var byte
        goto ir_send
    Goto Main
    ir_send:
         	cycles=zecime
            acycles=unu
     for i=1 to 4
            call Pulse
            pauseus  delay
            call Pulser
     next i
    Pauseus 100
    Goto main        ' or Return, have no result !
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
       bsf gpio, 2     ; 1uS, LED=on
       bcf gpio, 2     ; 1uS, LED=off
       return           ; Add 2uS for return to caller
    Pulser:              ' Generate "Cycles" number of 40kHz pulses
       decfsz _Acycles,f ; + 1uS = 10S
       goto _Pulser      ; + 2uS = 12uS
    Thanks again for attention !
    Dec 2008
    Ploiesti, ROMANIA
    On first row: original Blaupunkt remote, volume up command.
    On second row : my remote, volume up command.
    Using same sensor (original Blaupunkt).
    Original-work; my-NO !!! I'm stuck, dissapointed, sad...
