Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes, I know...
    ...and I say in previous post :
              Cycles = 102      ' 102 * 26 = 2652 uS
              CALL Pulse38
              Pauseus 2580      ' accurate pause of 2580 uS ?!?
              Cycles = 25       ' 25 * 26 = 650 uS ; maybe must EXACTLY 660 uS - how ?!?
    Suggestions ? Thank You for attention !
    You may very well declare a 1234usec delay but this depends on the accuracy of the System Clock (Crystal resonator or what ever).
    So you may have to trim a little the value of the pauseus to get exactly the time you want.
    In general IR systems I eel are able to tolerate such skews...
    Dec 2008
    Ploiesti, ROMANIA
    Default YES ! Finally I have results !
    After thousands of re-writing this code, I've got finally results :
    @ DEVICE PIC12F675, INTRC_OSC_NOCLKOUT, wdt_off, pwrt_off, mclr_off, bod_off
    CMCON = 7               ' Comparators disabled
    ANSEL = 0               ' A/D disabled
    @ #define IRTX GPIO     ; Define port to use for IR out
    @ #define PIN 1         ; Define port pin for IR out
     Puls_a         CON 112  ' 112 x 26uS = 2912 mS ( pulse with carrier ON)
    InterPulse  CON 2800 ' 2.80mS (delay between pulses with carrier OFF)
    Puls_b        CON 28   ' 28 x 26uS = 728 uS   ( pulse with carrier ON)
    X        VAR BYTE ' Data bit loop counter & bit index pointer
    Duration VAR BYTE ' Duration of button press
    Loops    VAR BYTE ' Loop count
    Cycles   VAR BYTE BANK0 SYSTEM' Number of carrier cycles to generate
    trisio=%11111101
    option_reg.7=0
    wpu	=%11111101
    but  var gpio.5
        GOTO Main       ' Jump over pulse routine to Main
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
    ASM                 ; Keep this routine in code page 1, and jump over to Main
       	BSF	IRTX,PIN		      ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	BCF	IRTX,PIN		      ; 1 MAKE IR LOW 17 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	DECFSZ	Cycles,F
    	GOTO	_Pulse	      ; 2    26 uS
       return           ' Return to caller
    Duration = 2    ' Send it twice
    IF BUT=0 THEN
    For Duration = 1 to 2
            Cycles = Synch         ' carrier on
            Call Puls_a             ' Send pulse
            PAUSEUS InterPulse    ' Pause (carrier off)
            Cycles = Logic0        ' carrier on
            Call Puls_b             ' Send pulse
    		Pauseus 50000
    		Pauseus 50000
    Next Duration
        GOTO Main                  ' Return for more
    This is command for Volume Up only ; instead 102 cycles * 26 uS = 2650 uS, I put 112 * 26 = 2912, etc. So, the lenght of one pulse is 23.5 uS ?! Maybe with this PIC... Anyway, it's good to see that working, after hard work... Thank You all for support; every advice it's further wellcome !
    It seems that the internal RC oscilator is not precise at least for the receiver you use.
    It cannot tolerate small differencies of the transmission pulse width.
    Either use a crystal oscillator or trim your delays so that they get precisely the value needed.
    Dec 2008
    Ploiesti, ROMANIA
    Using PIC 16F628A I build this remote-by-wire for my Blaupunkt Radio-SD Card. Work verry fine... even it's simple and can be improved.
    ; Simple Remote-by-wire for Blaupunkt ; use RC10 protocol
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    DEFINE  OSC 4      ; USE 4 MHz crystal
    TRISA= %00000000
    TRISB= %00011111
    CMCON=7
    TO_BLAU VAR PORTA.0
    TO_BLAU = 1
    PULSA	VAR WORD
    PULSB	VAR WORD
    I	VAR BYTE
    DELAYS  CON 660
    MAIN :
    PAUSE 500
        	IF PORTB.0 = 0 THEN        'volume +
        	PULSA=2650
        	PULSB=2580
        	GOSUB PULSE
    	IF PORTB.1 = 0 THEN        'volume -
    	PULSA = 3250
    	PULSB = 3200
    	GOSUB PULSE
    	IF PORTB.2 = 0 THEN        'mute
        	PULSA = 5050
        	PULSB = 5000
    	GOSUB PULSE
        	IF PORTB.3 = 0 THEN        'SRC aka Source
    	PULSA = 6875
    	PULSB = 6850
        	GOSUB PULSE
        	IF PORTB.4 = 0 THEN        'Next aka Right
    	PULSA = 5660
    	PULSB = 5630
        	GOSUB PULSE
    GOTO MAIN
    ;SUBROUTINE
    PULSE:
    	FOR I = 1 TO 10
    		LOW TO_BLAU
    		PAUSEUS PULSA
    		HIGH TO_BLAU
    		PAUSEUS PULSB
    		LOW TO_BLAU
    		PAUSEUS DELAYS
    		HIGH TO_BLAU
    		PAUSEUS 50000
    		PAUSEUS 50000
    	NEXT I
