Sony IR Remote
Results 1 to 40 of 41
Thread: Sony IR Remote
    It seems that the internal RC oscilator is not precise at least for the receiver you use.
    It cannot tolerate small differencies of the transmission pulse width.
    Either use a crystal oscillator or trim your delays so that they get precisely the value needed.
    Dec 2008
    Ploiesti, ROMANIA
    Using PIC 16F628A I build this remote-by-wire for my Blaupunkt Radio-SD Card. Work verry fine... even it's simple and can be improved.
    ; Simple Remote-by-wire for Blaupunkt ; use RC10 protocol
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    DEFINE  OSC 4      ; USE 4 MHz crystal
    TRISA= %00000000
    TRISB= %00011111
    CMCON=7
    TO_BLAU VAR PORTA.0
    TO_BLAU = 1
    PULSA	VAR WORD
    PULSB	VAR WORD
    I	VAR BYTE
    DELAYS  CON 660
    MAIN :
    PAUSE 500
        	IF PORTB.0 = 0 THEN        'volume +
        	PULSA=2650
        	PULSB=2580
        	GOSUB PULSE
    	IF PORTB.1 = 0 THEN        'volume -
    	PULSA = 3250
    	PULSB = 3200
    	GOSUB PULSE
    	IF PORTB.2 = 0 THEN        'mute
        	PULSA = 5050
        	PULSB = 5000
    	GOSUB PULSE
        	IF PORTB.3 = 0 THEN        'SRC aka Source
    	PULSA = 6875
    	PULSB = 6850
        	GOSUB PULSE
        	IF PORTB.4 = 0 THEN        'Next aka Right
    	PULSA = 5660
    	PULSB = 5630
        	GOSUB PULSE
    GOTO MAIN
    ;SUBROUTINE
    PULSE:
    	FOR I = 1 TO 10
    		LOW TO_BLAU
    		PAUSEUS PULSA
    		HIGH TO_BLAU
    		PAUSEUS PULSB
    		LOW TO_BLAU
    		PAUSEUS DELAYS
    		HIGH TO_BLAU
    		PAUSEUS 50000
    		PAUSEUS 50000
    	NEXT I
