PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default I agree with using interrupts to measure time
    Scalerobotics.
    I have not been successful getting the RC knowledgeable folks to come clean with the exact signal pulse width specs. The hobby RC folks at our local RC Excitement racetracks and store
    http://www.rcexcitement.com/
    say that neutral (braking) is 130ms. This makes sense if the max pulse size is 256ms (2 to the 8th for convenient digital counting). How often that pulse is expected I am not sure. I think I read that the shortest pulse is about 50ms and the longest about 200ms. But I have no idea where or how I got that impression.
    It would be nice if I could implement a program on my PICkit such that my eyes could detect this variation by observing the glow of an LED.
    I neither own an oscilloscope nor have easy access to one. I do have some contacts at the Fitchburg State College Computer Science Department. I could call them and take over my car for a definitive answer.
    Enough talk. I'm supposed to be thinking and tinkering.
    Ken
    Most of the RC stuff out there uses something like this, but there are exceptions:
    And it is done 50 times per second, or every 20ms.
    The hobby RC folks at our local RC Excitement racetracks and store say that neutral (braking) is 130ms.
    I think the guys at your RC Excitement might be off by a decimal point or two if they are telling you neutral is 130ms.
    If that was neutral, it would take about 1 second to make any corrections to steering or throttle. In my mind that is a little slower than you need for a fast car like the one I saw in your other thread.
    Most RC receivers send out a pulse, one at a time, to each servo. So with the longest (2ms) pulse, an eight channel receiver can still fit all 8 x 2ms pulses in the 20ms bandwidth given by the cyclic 50 times per second update rate.
    Nov 2009
    Fitchburg, Mass
    Default You are absolutely correct!
    These RC Excitement guys just said 150 and 125 and 175. They never said the units. I just surmised milliseconds.
    Last week you sent me two short programs. You also suggested that I go to Darrel Taylor's page and grab some code. I got his "blinky" to compile and work with the minor adjustments of changing the output to an LED register and the DT_INT-14.bas fix. I never got either of yours to compile and run.
    On page 125 of your 18F2520 spec I found T0CON containing TMR0ON, T08BIT, T0CS, T0SE, PSA, T0PS2 AND T0PS1. I could not relate any of this to the contents of pages near 77 of my 16F887 spec. I also could not find in any code you posted where you set these bits.
    Scalerobotics thought I might be able to measure the PWM radio receiver outputs if I converted it to a serial stream. Good idea, but I don't know what to do with a serial signal.
    I would feel successful if I could see on a flashing LED that my radio receiver is working and that the PIC can read it. (I know it is working because the car wheels turn.) This is the intent of the first code (RC-Input - 12F675) Scalerobotics sent me. It originate with Malcolm from Hertfordshire, UK.
    I'd like to get that working.
    Time out. Gotta check the TV for results of the Massachusetts special US Senatorial election.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default Another eureka moment
    You guys keep suggesting the serial signal. Could it be that you have a method of debugging/trouble shooting your microprocessor code on line?
    I just looked up USB on wikipedia. It is a "Universal Serial Buss" OH! I did not know that. So NOW I look at the "view" pull down menu on my MicroCode Studio GUI and discover "Serial Communicator" and "Easy HID USB Wizard".
    There is clearly a lot for me to learn in C:\PBP\USB. Is that where I should start? I just opened MPLAB IDE for which I could see no purpose. I am beginning to understand but I am not sure where to start.
    Ken
    Mine will only compile properly for a PIC18F device, for sure with a PIC18F2520. It will need some work to translate for PIC16F devices.
    Sorry, it is page 75 in the datasheet, and page 77 on Acrobat. Look for the page that has:
    REGISTER 5-1: OPTION_REG: OPTION REGISTER on it. Where I set these registers is here:
    T0CON = %00000001
    T1CON = %00000001
    T2CON = %01011111
    CCP1CON = %00000101
    You mean you don't have any computers laying around with a serial port? Yeah, I guess it is like that in my house too! Your PicKit2 comes with a great resource (in my opinion). It has a serial port built in, and you can use it to see what your program is doing. Or in this case, figure out what your Pulse Width Measurement is doing. With the Pickit2 software, go to tools, then choose the Uart tool. Make sure you are sending your serial data to the right pin. In this case, you will have to use the serout commands, as the pickit pins will not be connected the the hardware serial port. Follow the serout as defined in the PBP manual.
    LED's can be a good trouble shooting tool. However, we do not even know if the timebase is going to be similar in your chip, or what crystal you are running, etc. The serial port will be able to tell you so much more about what is going on. I think you will feel even more satisfied seeing actual results.
    Me too!
    One thing I learned about was MicroCode Studio's ICD (in circuit debugger). It is a great tool to see what your code is doing. It lets you step through, or view it, while allowing you to view registers, etc. I used it a lot in the beginning, then I started a few projects that were very time dependent, so I could not use the ICD in them, so I have not used it in a long time.
    And about that USB HID ... what about the back to basics part?
    -Walter
    Ken,
    Get a USB to serial converter. You do not want to mess with USB from the PIC at this time. Keep it simple.
    The use the serial terminal in MCS.
    Nov 2009
    Fitchburg, Mass
    Default Looks like the PICkit Logic Tool is my answer
    I have discovered the Analyzer Tool in the PICkit Tool Logic Tool package.
    It looks like this tool will provide me a picture of the output of my radio receiver if I can get Scalerobotics' program to work. I have both MPLAB IDE and PICbasic PRO packages. They have some duplications. I have a book "PIC PROJECTS" which pontificates the advantages of MPLAB. I have an impressive PICkit Tool HELP menu.
    My impression is that the PICkit package is what I should focus upon. Does that make sense?
    Ken
    Nov 2009
    Fitchburg, Mass
    Default I am completely lost.....
    I succeeded in getting scalerobotics second code sample to compile.
    This is the one that samples PWM incoming and puts it out the serial port. It created an .asm file that would not build. The list of errors is too large to publish here. (Besides that it does not word wrap well.)
    I am completely missing something. I do not understand PICBASIC PRO.The multiple hundred page microchip DATA SHEETS blow my mind. I try to read a section (16F887 Page 74 on SOFTWARE PROGRAMMABLE PRESCALER) and I can not put it in context.
    I am not sure where the basics are that I am meant to go back to. I have a couple of paperback books. Maybe I should read page by page.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
