PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Default Thank you both
    I awoke this morning looking out my window onto eight new inches of wind packed snow. Plenty of time to think.
    What scalerobotics said makes sense to me. In 1957 I was programming the AN/FSQ-7 SAGE Air Defense computer. We worked in machine language. It took us years to develop and distribute a symbol and subroutine library sufficient to allow us to focus on the radar data reading, intercept calculating algorithms needed to accomplish air defense. Building this subroutine library was a big task. The architecture of the machine did not change.
    This morning I said to myself, "Back to basics." It may have been a mistake for me to purchase PICbasic PRO. Without being able to tap into the developments of others on the 16F88x structure, I may be better off in ASM. That way I will be forced back to basics.
    This world of microprocessors reopens the academic importance of old fashioned "computer science". I was afraid that we had become too product oriented to care what is a "register".
    I have two PIC books:
    PIC PROJECTS by Parchizadeh and Vuksanovic
    and
    RUNNING SMALL MOTORS WITH PIC MICROCONTROLLERS by Sandhu
    Seems like I should cease dreaming of getting a prototype to blink in sync with a PWM input signal and get back to the books. I've got plenty of time. Did I mention that we are snowed in without an all wheel drive car?
    Ken
    Ken
    Ken, I hope I did not discourage, for it was my intent to encourage. But back to basics is always a good idea, no matter what path you choose. For PIC devices, it can be a difficult task to transfer a program from one type of device to another.
    A better place to start on the learning curve, might be to use Darrel Taylors interrupt code examples, and try to get the interrupt blinking led going on your device. Then try to modify it in some way that is closer to the end product you want. In that way, it forces you to learn about different registers, but only a few at a time. Here is Darrels blinky example. http://darreltaylor.com/DT_INTS-14/blinky.html
    Joe had some great advice. In trouble shooting, it is always helpful to figure out what parts of the code DO work. I always like using the serial port to help tell me what is happening in the device, and to check register values, etc.
    Let us know how we can help you.
    Walter
    Nov 2009
    Fitchburg, Mass
    Default where are the ASM macros stored?
    I got Darrel Taylor's blinky to work on my PICkit 2 16F887. I had to change the output pin to the LED to match the printed circuit on the 44 pin demo board.
    Now I would like to get blinky to interrupt on the rising edge and the falling edge of a signal coming in CCP1 which is RC2.
    Darrel Taylor's blinky contains this line
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    Where do I look for the definition of INT_ENABLE? I used SEARCH. I had no luck at all.
    Ken
    That's a great start Ken!
    INT_ENABLE is a Darrel Taylor command for his DT_INTS. This is the same as enabling, or disabling a certain interrupt. To set up CCP interrupts, you first add a line like my code had:
    INT_Handler   CCP1_INT,      PWMeasure,   ASM,  yes
    Then enable it:
    @ INT_ENABLE CCP1_INT
    But you will also have to configure it. Make portc.2 an input. And configure your CCP1
    CCP1CON = %00000101 ;capture every rising edge
    Now I used Chuck's code to do the capture. It needs the sub16.inc include file to be included, and we will need some variables like
    risetime var word      ;used for pulse width measure start of pw
    falltime var word      ;time at end of pulse width
    falltime_l var falltime.byte0
    falltime_h var falltime.byte1
    risetime_l var risetime.byte0
    risetime_h var risetime.byte1
    asm
    PWMeasure
        BTFSS   CCP1CON, CCP1M0 ; Check for falling edge watch
        GOTO    FALL_EDGE       ; Go pick up the falling edge
        MOVF    CCPR1L,W        ; else store leading edge value
        MOVWF   _risetime_l         ; into 16 bit word risetime
        MOVF    CCPR1H,W
        MOVWF   _risetime_h
        BCF     CCP1CON, CCP1M0 ; Now capture the trailing edge
        GOTO    ISR_2           ; Exit the interrupt service routine
    FALL_EDGE:
        BSF     CCP1CON, CCP1M0 ; Re-set for trailing edge capture
        MOVF    CCPR1L,W        ; Store the captured value into
        MOVWF   _falltime_l         ; falltime_l and ...
        MOVF    CCPR1H,W
        MOVWF   _falltime_h       ;             ... falltime_h
        ; 16 bit subtract
        ;     falltime = falltime - risetime
        SUB16   _falltime, _risetime
    ISR_2
        INT_RETURN
    endasm
    Now, if you read the data sheet, you see in 11.1 Table 11-1 that capture mode uses timer1. So you will have to set this. Looks like it may be same settings as I have in T1CON. This will also start the timer. It runs continuously, and we don't care about interrupts on T1. We just want to read the timer at interrupt high edge of CCP1, and read timer on low edge of pulse. Then we should have a value present at falltime, representing the length of the pulse.
    Nov 2009
    Fitchburg, Mass
    Default Omg
    I did not expect this project to be so discombobulating.
    Thanks to this forum's help, I think I will get it.
    ken
    Yes, you have picked a very challenging project.
    The servo part broken down into basic steps of what is going on here. (Other interrupt sources, and different timers could be substituted, but this is what I am using).
    __________________________________________________ _________________________________________________
    Pulse Sensing:
    Using CCP interrupt and calculate (pulse_width = falltime - risetime) with CCP capture low byte CCPR1L and capture high byte CCPR1H (these use Timer1). To do this, bits must be changed from capture on rise, to capture on fall.
    Pulse Width Generation:
    Need to create interrupt from about 1ms to 2ms in length. To do this, we load a timer with pulse width value, bring servo pin high, start timer, when interrupt occurs, bring servo pin low. I used Timer0.
    Pulse Period Generation:
    Need to generate 20ms time frame for sending servo signals. I used Timer2. Servo out pins need to pulse every 20 ms.
    On a side note:
    Now just to discombobulate things a little bit (more!), cheating can sometimes work. Problem is, that you want to run one of your outputs through a motor controller, and these don't like cheaters. They like very reliable 20ms time (Pulse Period) frames for the servo pulses. So, where you might have gotten away with using PBP's pulsin and pulsout commands for sensing and controlling servo's, you will not get away with using the pulsout command for controlling your motor controller.
    One place you could get away with a little cheating, is to use Pulsin command to sense your receiver's servo pulses. Then you would not have to worry about the servo Pulse Width sensing. I have used this with an RC autopilot project, and it was smooth enough to fly. But, since you are doing all this work learning about interrupts, and timers, you might as well do it the right way, and measure the pulse with an interrupt.
    Nov 2009
    Fitchburg, Mass
    Default I agree with using interrupts to measure time
    Scalerobotics.
    I have not been successful getting the RC knowledgeable folks to come clean with the exact signal pulse width specs. The hobby RC folks at our local RC Excitement racetracks and store
    http://www.rcexcitement.com/
    say that neutral (braking) is 130ms. This makes sense if the max pulse size is 256ms (2 to the 8th for convenient digital counting). How often that pulse is expected I am not sure. I think I read that the shortest pulse is about 50ms and the longest about 200ms. But I have no idea where or how I got that impression.
    It would be nice if I could implement a program on my PICkit such that my eyes could detect this variation by observing the glow of an LED.
    I neither own an oscilloscope nor have easy access to one. I do have some contacts at the Fitchburg State College Computer Science Department. I could call them and take over my car for a definitive answer.
    Enough talk. I'm supposed to be thinking and tinkering.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
