PBP projects for R/C models
Results 1 to 40 of 772
    Ken,
    If you're working with PBP, you need to forget about anything you read for the Mikroe BASIC compiler. These are two totally different compilers.
    Everything you need to know about PBP is in the PBP manual. What you don't understand, just ask about here.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Ken,
    Have you been to this page?
    http://www.melabs.com/resources/samples.htm
    As for routines. I would say that just about every "command" listed in the PBP manual is a routine. ADCIN for example. The routine for reading the chip's ADC is built into that command.
    Keep asking questions
    Nov 2009
    Fitchburg, Mass
    Smile Success - the wheels go round
    This PWM exercise is designed just for what I have done.
    http://www.melabs.com/resources/samples/pbp/hardpwm.bas
    After loading the .hex into the RC car (carrying my PICkit2), hooking up another battery and connecting CCP1 to the electronic speed control, The wheels spin!!
    Ain't technology grande!
    Ken
    COOL!!!
    Another piece down!
    Did you get Walter's PWM reading code to work?
    If so then maybe now you can combine the two.
    If incoming PWM is X then wheels turn sort of thing?
    Nov 2009
    Fitchburg, Mass
    Default How does PICkit 2 Logic Tool work?
    As I said, the wheels go round, but...
    The wheels are not going round and round in the pattern I expected. In particular they only go backwards. The code claims to sweep from 20% to 80% cuty cycle.
    SOOO, can I use my USB connection and PICkit 2 Logic and Analyze Tool to see what is actually happening?
    Ken
    I believe you are using the PWM example here: http://www.melabs.com/resources/samples/pbp/hardpwm.bas
    This is a PWM that is not supposed to work with RC servo's. It's wave form is different. It is used to dim LED's etc. I am a little surprised that it can turn the wheels at all. I have a scope to help me view wave forms. I have tried for a few minutes to see what the pickit's logic tool can do, but I have not had any success. I am pretty sure it is just a problem with the operator (me).
    May 2007
    This is what the program header says:
    ' PicBasic Pro Program to demonstrate hardware PWM.
    ' Output is a 1Khz signal with duty cycle sweeping
    ' from 20% to 80% once per second
    Since the frequency is 1KHz, its period is 1mS. The duty cycle is sweeping from 20% to 80% therefore the pulse width is varying from 0.2mS to 0.8mS. There are 2 problems here. For R/C signals, the period should be 20mS or 50Hz. Second, the pulse width should be 1.5mS for neutral, 1.0mS for extreme left (or full reverse) and 2.0mS for extreme right (or full forward). So your car is responding to a very short pulse (even less than full reverse). You have to modify the values in the program to get it to do what you expect.
    Nov 2009
    Fitchburg, Mass
    Default Thank you for your analysis
    Thanks gang.
    I came to much the same conclusion myself. I have been trying to figure out what exactly this PWM code does so that I can modify it meet the RC specs. The comments in the program are fairly clear. My first attempts have not worked but I am optimistic.
    Interesting how rusty my brain has become.
    Ken
    May 2007
    I gave you that info in post #44.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
