PBP projects for R/C models
Results 1 to 40 of 772
    Ken,
    Have you been to this page?
    http://www.melabs.com/resources/samples.htm
    As for routines. I would say that just about every "command" listed in the PBP manual is a routine. ADCIN for example. The routine for reading the chip's ADC is built into that command.
    Keep asking questions
    Nov 2009
    Fitchburg, Mass
    Smile Success - the wheels go round
    This PWM exercise is designed just for what I have done.
    http://www.melabs.com/resources/samples/pbp/hardpwm.bas
    After loading the .hex into the RC car (carrying my PICkit2), hooking up another battery and connecting CCP1 to the electronic speed control, The wheels spin!!
    Ain't technology grande!
    Ken
    COOL!!!
    Another piece down!
    Did you get Walter's PWM reading code to work?
    If so then maybe now you can combine the two.
    If incoming PWM is X then wheels turn sort of thing?
    Nov 2009
    Fitchburg, Mass
    Default How does PICkit 2 Logic Tool work?
    As I said, the wheels go round, but...
    The wheels are not going round and round in the pattern I expected. In particular they only go backwards. The code claims to sweep from 20% to 80% cuty cycle.
    SOOO, can I use my USB connection and PICkit 2 Logic and Analyze Tool to see what is actually happening?
    Ken
    I believe you are using the PWM example here: http://www.melabs.com/resources/samples/pbp/hardpwm.bas
    This is a PWM that is not supposed to work with RC servo's. It's wave form is different. It is used to dim LED's etc. I am a little surprised that it can turn the wheels at all. I have a scope to help me view wave forms. I have tried for a few minutes to see what the pickit's logic tool can do, but I have not had any success. I am pretty sure it is just a problem with the operator (me).
    May 2007
    This is what the program header says:
    ' PicBasic Pro Program to demonstrate hardware PWM.
    ' Output is a 1Khz signal with duty cycle sweeping
    ' from 20% to 80% once per second
    Since the frequency is 1KHz, its period is 1mS. The duty cycle is sweeping from 20% to 80% therefore the pulse width is varying from 0.2mS to 0.8mS. There are 2 problems here. For R/C signals, the period should be 20mS or 50Hz. Second, the pulse width should be 1.5mS for neutral, 1.0mS for extreme left (or full reverse) and 2.0mS for extreme right (or full forward). So your car is responding to a very short pulse (even less than full reverse). You have to modify the values in the program to get it to do what you expect.
    Nov 2009
    Fitchburg, Mass
    Default Thank you for your analysis
    Thanks gang.
    I came to much the same conclusion myself. I have been trying to figure out what exactly this PWM code does so that I can modify it meet the RC specs. The comments in the program are fairly clear. My first attempts have not worked but I am optimistic.
    Interesting how rusty my brain has become.
    Ken
    Nov 2009
    Fitchburg, Mass
    Default All Right, I get it!
    Here is the code that makes the wheels spin.
    There are no PBP commands that overtly make pulses. They are created by appropriately loading CCP1CON and CCPR1L. I found CCP1CON easily enough. It is listed in the INDEX of the 16F887 Data Sheet. CCPRxL and CCPRxH are not in INDEX. They are quietly mentioned on page 127. But why is there no HPWM command per page 86 in the PBP manual?
    Although I see how this might be a low cpu overhead way to create PWM, I don't want to learn about this now. I want to use PBP and ASM commands to control my motor and servo. Maybe tomorrow all this will make sense.
    Ken
    May 2007
    I gave you that info in post #44.
    Nov 2009
    Fitchburg, Mass
    Default Yes, we are all in agreement except..
    Thank you all for your help. I posted those quotes because they back up what you have been saying and what I thought I coded.
    Trouble is my PIC code only makes my car wheels go backwards and stop. I have not been able to create a PWM stream that drives the wheels forward. I know the ESC works because the wheels go fine under radio control.
    Oscilloscope, here I come.
    Ken
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
    Last Post: - 28th September 2021, 11:26
    By forgie in forum General
