pulsin again!anyone plz help!
Results 1 to 36 of 36
    Default Re: pulsin again!anyone plz help!
    if tmp >= 500 then
    Will never be as tmp is BYTE size
    Aug 2010
    Maryland, USA
    Every iteration of your loop turns the led off right after start. There's you problem.
    -Bert
    Mar 2011
    thanks for reply everyone..
    @demon and mackaraket guys the above code is working there is nth wrong with it.i just want to add an additional functionality of on/off...
    @cncmachineguy i didnt understand your reply can u elaborate a little.... plz
    Aug 2010
    Maryland, USA
    Start:
    LOW SONYLED <-------------------------Here you turn off the LED
    IRBUTTON=255: IRDEVICE=255
    Pulsin irin,0,header
    if header < 1000 or header > 1350 then goto Start
    check:
    for i =0 to 11
    pulsin irin,0,tmp
    if tmp >= 500 then
    Body.0[i]=1 'Sony Logic 1 is 120
    Body.0[i]=0 ' Sony Logic 0 is 60
    next
    IRBUTTON = Body & %01111111
    if IRBUTTON <=9 then
    loop:
    toggle Sonyled '<----------------------change!
    goto start  <--------sends program back to the beginning, this will turn off the LED
    -Bert
    if tmp >= 500 then
    Very good, a byte can count from 0 to 255.
    That could give unpredictable results (except for the gurus that can most likely figure exactly how it will go screwy ); it may work, it may not.
    Aug 2010
    Maryland, USA
    @ Demon, I do not at all to be a guru who could figure out how it will go screwy, I am fairly certain IRBUTTON is ALWAYS = 0 after his for loop. Since there is NO way to cram a number bigger then %11111111,$FF,255 in a byte, it will always do the else setting all 11 bits to zero.
    So I would certainly question the OP's statement that it works, I think it prolly does in fact receive the signal, and detect the header. but I think from there it will fail as soon as it is tested for specific button presses.
    We shall wait and see
    -Bert
    without to check your code i think you should consider the frames (codes) of the ir Sony protocol... because Sony remotes all appear to repeat each frame a minimum of 3 times...and also i think you toggle the led by pressing too long time the button on the remote ..... add some some long pause for test
    Mar 2011
    @cncmachineguy thanx a lot for pointing me the problem.i ve been a fool n i admit... the toggle function works fine... thanx v much again your approach has been dead on...g8 advice for beginners!!
    @demon u r right as well.the code is working for all the buttons of my remote(unexpected results)... not for just button <9 .problem wid temp most probably... i'll declare it a WORD n c how it goes...!
    @bogden thanks for your input as well. i have put a delay of 100...
    Mar 2011
    my final code it is toggling on button 6 of your sony remote.n the good thing is no interrupts or timers simple code
    @ DEVICE pic16F877a, WDT_OFF  ' Watchdog Timer
    @ DEVICE pic16F877a, PWRT_OFF  ' Power-On Timer
    @ DEVICE pic16F877a, BOD_OFF  ' Brown-Out Detect
    @ DEVICE pic16F877a, LVP_OFF  ' Low-Voltage Programming
    @ DEVICE pic16F877a, CPD_OFF  ' Data Memory Code Protect
    @ DEVICE pic16F877a, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877a, HS_OSC
    Define OSC 20
    cmcon=2
    Header var word
    Body var word
    i var byte
    tmp var word
    irButton var byte
    irDevice var byte
    irIN var PortB.2
    SonyLED var PortB.5
    TrisB = %00000100
    Start:
    'LOW SONYLED
    check:
    for i =0 to 11
    pulsin irin,0,tmp
    if tmp >= 500 then
    next
    if IRBUTTON=5  then
    loop:
    toggle Sonyled
    goto start
    copy/paste n njoy love PBP!!!!
    Insignificant, but I would change this:
    if IRBUTTON=5  then
    loop:
    toggle Sonyled
    To this:
    if IRBUTTON=5  then toggle Sonyled
