here you go:
Code:'**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 5/23/2011 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** 'include "ALLDIGITAL.pbp" @ DEVICE pic16F877a, WDT_OFF ' Watchdog Timer @ DEVICE pic16F877a, PWRT_OFF ' Power-On Timer @ DEVICE pic16F877a, BOD_OFF ' Brown-Out Detect @ DEVICE pic16F877a, LVP_OFF ' Low-Voltage Programming @ DEVICE pic16F877a, CPD_OFF ' Data Memory Code Protect @ DEVICE pic16F877a, PROTECT_OFF ' Program Code Protection @ DEVICE pic16F877a, HS_OSC Define OSC 20 cmcon=2 Header var word Body var word i var byte tmp var Byte irButton var byte irDevice var byte irIN var PortB.2 SonyLED var PortB.5 'TrisA = %00000100 TrisB = %00000100 Start: LOW SONYLED IRBUTTON=255: IRDEVICE=255 Pulsin irin,0,header if header < 1000 or header > 1350 then goto Start check: for i =0 to 11 pulsin irin,0,tmp if tmp >= 500 then Body.0[i]=1 'Sony Logic 1 is 120 else Body.0[i]=0 ' Sony Logic 0 is 60 endif next IRBUTTON = Body & %01111111 if IRBUTTON <=9 then loop: toggle Sonyled '<----------------------change! endif pause 100 goto start
