pulsin again!anyone plz help!
Results 1 to 36 of 36
    Default Re: pulsin again!anyone plz help!
    Hello,
    I have to ask what exactly is your circuit doing or not doing? Does it do anything ?
    Does it flash the LED ? This question next is not designed to offend you . . . Have you checked all of your connections for errors and continuity? Breadboard errors trip me up regularly as do poor connections caused by internal corrosion in the breadboards. You buy one, and unbeknownst to you, it sat on the dealer's shelf for ten years . . . and all the contacts are corroded. I have disassembled some that were really scuzzy.
    One more thing, I think portB inputs default to weak pull ups on, turn them off in the option register.
    EDIT: Nope default off. Easy to check with a hi impedance voltmeter though.
    Last question: are you measuring a high pulse or a low pulse? State 0, indicates a low pulse, is that correct?
    Mar 2011
    thanku archangel sir for replying.
    now the basic purpose of my project is to turn a relay on or off using sirc(sony protocol).
    for this i need to decode just two keysne for on and one for off.or maybe just one key that if a user presses a button 5v appear on output pin and if it presses the same button then it turns off!!this is one point...
    the next point is that the above code is working for
    if IRBUTTON >=0 and IRBUTTON < 255 then
    but not working for
    if irbutton=16 then high sony led '16 is for channel up
    it is not working for this the above command
    this is the second point...
    and the third point is that i dont understand this
    EDIT: Nope default off. Easy to check with a hi impedance voltmeter though... cant understand this
    Last edited by Archangel; - 27th May 2011 at 01:56. Reason: code tags [code] your code [/code]
    OK, RE: I Dont understand . . .
    Just a small argument with myself . . .
    Let me explain my thought process, If the weak pullups were turned on, then applying voltage to that pin might go unnoticed by the MCU because voltage is already present . . .
    Let me ask you this, can you output the value of pulsin to an LCD display or to your computer to find out its value, or flash an LED the number stored therein ?
    That might give you some insight as to what is going on.
    EDIT:
    but not working for
    NOT IN POSTED CODE ! Maybe it never gets there, please post
    your code, use code tags as shown in the edit explanation at
    the bottom of your edited last post
    Mar 2011
    'include "ALLDIGITAL.pbp"
    @ DEVICE pic16F877a, WDT_OFF ' Watchdog Timer
    @ DEVICE pic16F877a, PWRT_OFF ' Power-On Timer
    @ DEVICE pic16F877a, BOD_OFF ' Brown-Out Detect
    @ DEVICE pic16F877a, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F877a, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F877a, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877a, HS_OSC
    Define OSC 20
    Header var word
    Body var word
    i var byte
    tmp var Byte
    irButton var byte
    irDevice var byte
    irIN var PortB.2
    SonyLED var PortB.5
    'TrisA = %00000100
    TrisB = %00000100
    Start:
    LOW SONYLED
    IRBUTTON=255: IRDEVICE=255
    Pulsin irin,0,header
    if header < 1000 or header > 1350 then goto Start
    for i =0 to 11
    pulsin irin,0,tmp
    if tmp >= 480 then
    Body.0[i]=1 'Sony Logic 1 is 120
    Body.0[i]=0 ' Sony Logic 0 is 60
    next
    IRBUTTON = Body & %01111111 'Mask 7 bit
    IRDEVICE = (Body >>7) & %00011111 'Mask 5 bit
    If IRDEVICE=255 then goto start
    high Sonyled
    pause 300
    low Sonyled
    goto start
    the above code works....
    but it is for all infrared buttons on the remote.i only want one button to do on/off of relay.if i replace this
    by this
    if IRBUTTON =16 then 'for channel up
    it is not working .
    Might be a good idea to display the value of .IRBUTTON on a terminal or LCD to see what is going on.
    Mar 2011
    sir how can i output the value of a button?? im using a sony tv remote...
    so i guess no way to output the value....
    Dave meant the value of the IRBUTTON variable.
    When developing software, sometimes you want to monitor what's happening INSIDE the PIC. Like Variables, Register, etc. The debatable lazy way is to use Simulator, but it doesn't solve any real life problem. So what many here do, is to send/display variables value on a LCD... or send it serially to your PC using Hyperterminal, MicroCode Studio Serial Communicator OR else so called "Terminal". If you have a PICKIT 2, you can use the built-in terminal utility.
    To me, when you do PIC stuff, you should have at least the following tools:
    1) Serial adapter To send/receive data to/from your PC AND/OR LCD (serial or Parallel)
    2) Logic Analyzer
    3) Scope
    For IR stuff, using a logic analyzer to record the incoming data make the whole thing a real piece of cake. You could also record the data with your PC soundcard with any decent Wav/Audio editor (SoundForge, Audacity, etc). Once you know what kind of signal comes in (or to be expected), it's easier to create/debug your code.
    HTH
