pulsin again!anyone plz help!
Results 1 to 36 of 36
    Mar 2011
    Default Re: pulsin again!anyone plz help!
    @ cncmachineguy
    sir it doesnt work because
    the led is high only when IRbutton is detected.... i want to keep it on forever ntil the next command without pressing the button...... is there any way?? maybe a function etc...???
    @archangel
    sir its difficult for me to understand it..the interrupt portion maybe if u could elaborate a little...
    or could point me out to an exmaple program....
    Lets see you non working code based on Bert's advice.
    Mar 2011
    here you go:
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 5/23/2011                                         *
    'include "ALLDIGITAL.pbp"
    @ DEVICE pic16F877a, WDT_OFF  ' Watchdog Timer
    @ DEVICE pic16F877a, PWRT_OFF  ' Power-On Timer
    @ DEVICE pic16F877a, BOD_OFF  ' Brown-Out Detect
    @ DEVICE pic16F877a, LVP_OFF  ' Low-Voltage Programming
    @ DEVICE pic16F877a, CPD_OFF  ' Data Memory Code Protect
    @ DEVICE pic16F877a, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877a, HS_OSC
    Define OSC 20
    cmcon=2
    Header var word
    Body var word
    i var byte
    tmp var Byte
    irButton var byte
    irDevice var byte
    irIN var PortB.2
    SonyLED var PortB.5
    'TrisA = %00000100
    TrisB = %00000100
    Start:
    LOW SONYLED
    IRBUTTON=255: IRDEVICE=255
    Pulsin irin,0,header
    if header < 1000 or header > 1350 then goto Start
    check:
    for i =0 to 11
    pulsin irin,0,tmp
    if tmp >= 500 then
    Body.0[i]=1 'Sony Logic 1 is 120
    Body.0[i]=0 ' Sony Logic 0 is 60
    next
    IRBUTTON = Body & %01111111
    if IRBUTTON <=9 then
    loop:
    toggle Sonyled       '<----------------------change!
    goto start
    Aug 2010
    Maryland, USA
    Irbutton will never be less then 9 because you and it with 127. So your if will always be false.
    -Bert
    Mar 2011
    so u r saying that i should and it with 65???
    BTW it works with less than 9....
    Aug 2010
    Maryland, USA
    I'm sorry, I am completely wrong. Need more coffee. I was thinking OR.
    -Bert
    Mar 2011
    np.you had me thinking there for a moment
    but my problem is the same just a pulse spike of 5 volts on button press i want to keep it permantently off or on when io press the button only once...
