Re: pulsin again!anyone plz help!
OK, RE: I Dont understand . . .
Just a small argument with myself . . .
Let me explain my thought process, If the weak pullups were turned on, then applying voltage to that pin might go unnoticed by the MCU because voltage is already present . . .
Let me ask you this, can you output the value of pulsin to an LCD display or to your computer to find out its value, or flash an LED the number stored therein ?
That might give you some insight as to what is going on.
EDIT:
but not working for
if irbutton=16 then high sony led '16 is for channel up
NOT IN POSTED CODE ! Maybe it never gets there, please post
your code, use code tags as shown in the edit explanation at
the bottom of your edited last post
Reason: add
